Help problem after clutch and axle install!
Ok so I have an integra gsr, and I just recently got my exedy stage 1 organic clutch installed and new axles installed. I am well past the break in point of the clutch, I have about 1000 miles on it already. But in second gear at around 2-3 thousand rpm my car begins to shake and vibrate a lot. This is under acceleration. Anyone know what could be the problem? Thanks in advance!
DID you torque everything down to specs? Locktite the flywheel bolts? when it shakes, is it when your turning, Straight line acceleration? Does it happen only in second gear?
blkhatch92
Oct 20, 2005 08:54 PM
