Clutch install problem
Old Nov 21, 2002 | 05:23 PM
I like my R's Avatar
Default Clutch install problem
Hello, I have a strange problem that neither my mechanic or I can diagnose. I dropped my car off at my mechanic to get an action stage 1KS clutch installed and I came back today to pick it up. He said that the car initially backed up out of the garage fine and proceeded to drive for a few seconds, but then the wheels no longer had any power. The engine starts, the transmission shifts through all gears fine, but the car won't move! The strange thing is, no matter what position the shifter is in, (including neutral), when the clutch pedal is not being pushed, the speedometer reads 20 km/hr (I have a Canadian car), and when I push the clutch in the speed goes down to zero. I don't know what's wrong, maybe you guys have an idea? Thanks a lot and sorry about the length of the post.
Old Nov 21, 2002 | 06:12 PM
FULLTHROTTLE's Avatar
Default Re: Clutch install problem (I like my R)
He didnt get an axle allthe way in and it must have popped out.
If the speedo is reading then the final drive is turning but the axles are not.
Put it up in the air and I bet you one of the axles worked its way out of the trans.
Old Nov 21, 2002 | 10:34 PM
Default Re: Clutch install problem (FULLTHROTTLE)
Thanks for your help FULLTHROTTLE, we found out what the problem was. It wasn't the axles, although I did suspect that too. He didn't align the pushrod that pushes the pressure plate onto the clutch disc right, so the clutch wasn't grabbing the flywheel.
Old Nov 21, 2002 | 10:37 PM
Type-Rare#1248's Avatar
lesson:
never let a guy work on your car unless he complete knows what he is doing
Old Nov 21, 2002 | 10:41 PM
lotus's Avatar
New User
Default Re: Clutch install problem (Type-Rare#1248)
I'm sure it was an honest mistake.. Kind of like when I forgot to tighten the cam gear bolts on my Datsun 2000 Sport.. I listened to the thing rattle for about 20 miles, pulling over to try to find the rattle many times..
Found it fine when the cam gear fell off and the motor went boom...
Old Nov 22, 2002 | 05:50 AM
Default Re: Clutch install problem (lotus)
Ouch. that still shouldnt have made the speedo work. Either way as long as its ok now.
Boosthead
Jan 25, 2005 07:36 AM
Boosthead
Jan 24, 2005 09:12 AM
apexxx
Jul 18, 2004 08:04 PM
JdmCIVIC853
Apr 20, 2003 01:25 PM
sCeRaXn
12
Mar 9, 2003 08:52 AM
