Manual P2P on Converted EK
Old Mar 3, 2011 | 05:34 AM
TiLLiiCoLLaPsE's Avatar
Default Manual P2P on Converted EK
Wats up guys, I recently converted my 2000 civic coupe ex to manual and ive been looking for a manual p2p to get everything running correctly but my automatic ecu has 4 plugs instead of 3 and the car wont start with the manual ecu. Would i need a wire harness or something? Any info would be greatly appreciated.
Old Mar 3, 2011 | 07:34 AM
Former User's Avatar
Default Re: Manual P2P on Converted EK
Is the manual ECU OBD2a or OBD2b?
Old Mar 3, 2011 | 07:53 AM
94EG8's Avatar
Seagull Management
Automatic ECUs have an extra plug, when using the manual plug just let it hang. I remember Katman saying years ago that automatic EX harnesses had unique issues that result in a no start condition when used in a 5 speed car, but I don't specifically know what has to be modified.
Old Mar 3, 2011 | 11:16 AM
Im not sure if the manual ecu was A or B because i was testing to buy it. Which should it be? Also should it work with no problems?
Old Mar 3, 2011 | 11:21 AM
Your 00 Civic is OBD2b. I asked because the OBD2a and 2b ECU connectors look similar; however, I don't know whether they can plug into the other ECU. The OBD2a and 2b plugs are pinned differently.
Old Mar 3, 2011 | 11:40 AM
RoadtripChris's Avatar
I can attest to RonJ@HT's statement. I just got a 1998 DX and I swapped a d15 into it. I ended up buying a P2P ECU just today, and through research I found that the plugs for OB2a and OBD2b are wired differently. Be careful on which one you get.
fryman
10
Mar 24, 2023 01:40 PM
sirb18a
May 26, 2013 09:13 PM
bubba cola
Jan 31, 2009 10:20 PM
deeweezy187
Aug 19, 2007 10:37 AM
