C5 motor dies when I give it gas. Car dies while driving.
Old Mar 2, 2011 | 04:04 AM
Black R's Avatar
25 Year Member
Icon6 C5 motor dies when I give it gas. Car dies while driving.
http://i27.photobucket.com/albums/c1...F/c4d905ba.mp4
The first couple of times I tried to rev it in this video, it just loses power when it goes over 3k - even though I'm pressing the gas pedal.
Then it finally just decides to rev normally at the end?
I already checked the injectors and ecu, spark, plugs I changed 7k miles ago. Brk7e11
I guess I'll double check the fuel pump, and the fuel pressure is stable.
I'm thinking maybe a vacuum line thats on the vacuum canister to itb's or something...
Old Mar 2, 2011 | 05:51 AM
Black R's Avatar
25 Year Member
Icon6 Re: C5 motor dies when I give it gas. Car dies while driving.
Oh yeah, and when I give it a bit of gas to try and hold at 3k rpm, the fuel pressure drops a bit and the rpms start going up and down. Now I'm leaning towards clogged fuel filter or bad fuel pump.
Old Mar 2, 2011 | 06:05 AM
CraterGrillo's Avatar
Default Re: C5 motor dies when I give it gas. Car dies while driving.
I was going to suggest clogged fuel filter, based on the symptoms.
Steve
Old Mar 2, 2011 | 12:33 PM
Black R's Avatar
25 Year Member
I went ahead and replaced the fuel filter with one from pep boys (purolator). That seems to have cured it.
I couldn't find anyone local with a walbro 255 in stock, but I have an old one at home I am going to throw in there just to rule it out.
Old Sep 12, 2011 | 05:27 AM
Black R's Avatar
25 Year Member
Update because this problem came back again recently:
I changed to a walbro pump, replaced fuel filter with oem honda.
I almost seems as if I sometimes have to free-rev over 4k rpm's and then the motor will 'break free' from whatever is causing it to do this...
I've double checked all the wiring.
Maybe I'll run some techron injector cleaner through just to be safe?
I'll recheck the distributor cap and rotor button as well...
Anything else I should check?
I have a sard fpr. Maybe I'll swap to aeromotive just to be safe?
Or perhaps it's tps or map sensor acting up?
*I'm using Crome pro with tps based mapping - the map sensor is used only for idle and light throttle cruising... It's on my vacuum canister.
Argh this is frustrating because it only happens once in a while!
Old Sep 12, 2011 | 10:06 AM
TOO MUCH TORQUE's Avatar
clean your iacv
Old Sep 12, 2011 | 12:19 PM
hksitr's Avatar
check tps as there could be a dead spot
Old Sep 12, 2011 | 12:36 PM
Agito's Avatar
check your valve lash and spark gap. Had a H22 make that type of bogging after a blip of throttle. lash was too tight on intake side.
Old Sep 12, 2011 | 02:36 PM
Black R's Avatar
25 Year Member
Originally Posted by TOO MUCH TORQUE
clean your iacv
Iacv isn't connected to the itbs at all.
I do have it still plugged into the wiring bc if I remove it, the idle will hunt.
Old Sep 12, 2011 | 02:39 PM
Black R's Avatar
25 Year Member
The plugs are gapped correctly, but I did set the valve lash a little tight on the toda cams the last time I set it...
Old Sep 12, 2011 | 02:42 PM
oldintegrao's Avatar
I would look into the O2 sensor. My primary sensor had been cut and extended by previous owner.
Old Sep 12, 2011 | 09:14 PM
Tiger_Si's Avatar
How about bad crankshaft sensor or bad distribution rotor.
Just throwing ideas, not really sure.
Old Sep 13, 2011 | 09:52 AM
KraZyCHOWMEIN's Avatar
Mine has been doing this for a while now randomly too. New ignitor, coil, rotor, wires, plugs, valve adjustment, fuel filter... same symptoms trying to give it gas and it just feels like it doesnt want to go anywhere.
Old Sep 15, 2011 | 07:38 AM
Black R's Avatar
25 Year Member
I've seen rotor button screw carnage for other people also, so I'll check that as well...
Old Sep 15, 2011 | 07:39 AM
Black R's Avatar
25 Year Member
Oh and I ran a bottle of techron through on my last fill up...
No issues since then *knock on wood*
Old Sep 15, 2011 | 07:49 AM
00TypeR's Avatar
As previously said, check you tps. Mine would bog at low rpm and act like no power. My tps had a dead spot. New tps fixed it.
Old Sep 15, 2011 | 09:28 AM
RGoose18's Avatar
I had this in my GSR, exact same symptoms
Mine felt like the injectors were going bad, but I never ended up getting it fixed. Keep us posted
Old Oct 9, 2011 | 01:36 PM
Black R's Avatar
25 Year Member
No issues to date after running that chevron fuel injector cleaner through a tank...
Tim Manhattan
Apr 21, 2012 08:48 PM
Black R
Mar 11, 2011 04:59 AM
89b20crx
Mar 8, 2011 09:54 AM
GraphiteMW
Feb 14, 2007 06:25 AM
RA12825
Jan 29, 2007 08:51 PM
