d16y8 dorman oil pans?
Old Mar 1, 2011 | 06:32 PM
mac51o's Avatar
Default d16y8 dorman oil pans?
well just bought a d16y8, the oil pan's leaking a little bit and the drain nut is chewed/stripped, so im thinking i just replace the whole pan/ gasket
anyways, i was wondering if anyone has tried dorman oil pans?
http://www.summitracing.com/parts/RNB-264-405/
or
where could i get a cheap original d16y8 oil pan?
Old Mar 2, 2011 | 09:19 AM
mac51o's Avatar
Default Re: d16y8 dorman oil pans?
bump
Old Mar 2, 2011 | 09:32 AM
grumblemarc's Avatar
The Grumpiest
I'm sure you can get a used on off of Ebay or the Marketplace much cheaper than that. I think you should be able to retap the drain plug and then replace the gasket.
Old Mar 2, 2011 | 02:38 PM
mac51o's Avatar
so far ebay i've seen prices are 80+
theres actually a small crack on pan, so i need to replace
bump, need one ASAP
Old Mar 2, 2011 | 02:54 PM
The Grumpiest
Haven't seen any reviews other than it being a steel pan so if you bottom out somehow it will bend and not break like the aluminum ones. Everything I've ever bought from Summit I've had no issues with.
I might give them a try on my new engine build.
Old Mar 2, 2011 | 06:43 PM
mac51o's Avatar
well i think im going to order the dorman from summit, but now the question is, WHAT GASKET SHOULD I USE?
Old Mar 3, 2011 | 03:06 AM
The Grumpiest
I don't understand the question. Get the gasket that fits the pan.
Old Mar 3, 2011 | 07:56 AM
mac51o's Avatar
i ve searched on summit, they didnt have one that fits,
so i should get a d16y8 gasket?
Old Mar 5, 2011 | 01:08 AM
mac51o's Avatar
bumps
Old Mar 5, 2011 | 01:54 AM
First.EG's Avatar
if the pan is for that motor then the oem gasket should fit right?
Old Mar 5, 2011 | 04:58 AM
Kista20's Avatar
yes the y5,y7,y8 all use the same pan gasket.
Old Oct 2, 2012 | 06:48 PM
thebeesknees015's Avatar
Sorry to res an old thread but I was wondering what the outcome of this was. I need a new pan as well and found that Summit was stocking the wrong pan. Did you end up replacing yours? I cant find anyone but the dealer who has the right one for the D16y8.
Old Oct 2, 2012 | 08:07 PM
furious94ls's Avatar
Spend the money, get an OEM pan. There are used ones on Ebay. Perfect fitment, dealer OEM gasket. No problems for the next 100k.
coehonda
May 4, 2010 01:29 AM
JDMCRX
Aug 2, 2007 03:03 PM
