Car stays on with Key on off
help help help!!!
92 honda accord LX wagon
the previous owner had an alarm but fail'd to tell me. so when i changed the steeringwheel. i took the battery terminal off to discharge the air bag. yada yada yada new steering wheel is on. car wont start. looked under. alarm brain sitting there. so i unplug'd the harness. car worked fine.
after time the RPM started to flicker while driving. then the whole car would shut off. and check engine light would go on. while the car is in motion i kickstarted it. and car turned on with check engine light. as i applied gas.. no fuel was feeding to the motor. hit a complete stop and car jsut shuts off. turn the key on off. chilled for 10 seconds. cranked. car started. then it happend all over again.
so now im here took out all the wires for the alarm and the brain of the alarm. note* none of the wires were spliced just crimp'd with another wire to plug in. now the car starts.. but wont turn off.
anyone have an idea?
lol, sorry man electrical issues can be hell. Get the helms manual and start from there, noone here can help you with such an issue as we can't look at the car like you can.
ok so i figured the problem to y the cars staying on. my friend retap'd all the points on the main relay and he sauder'd 2 points together. but the flickering of the RPM and the the car dying is still happening. someone told me it could be the dizzy. any input anyone?
Etorres325
Apr 2, 2010 12:27 PM
hondaStarter
15
Oct 25, 2009 05:02 PM
