Few questions after rear disc swap
Old Feb 28, 2011 | 03:59 AM
CWBETB's Avatar
Default Few questions after rear disc swap
Hello! I just had a rear disc swap done on my 1990 civic hatch. Few questions, what is the proper method for bleeding the brakes, rear then front, or criss cross etc. I am using the DX prop valve still, what kind of issues may I run into? Locking up, is it safe? The peddle is pretty soft now, not sure if that is more from bad bleeding or the prop valve. I am going to rebleed again to make sure though. Thanks for the help!
Old Feb 28, 2011 | 04:18 AM
slywfbpsi's Avatar
Default Re: Few questions after rear disc swap
RR->RL->FR->FL. You go the order that is furtherest away to the closest of your MC.
Old Feb 28, 2011 | 04:34 AM
CWBETB's Avatar
Thanks, just wondering, I have seen doing a criss cross method also, is that specific for cars with ABS?
Old Feb 28, 2011 | 05:56 AM
slywfbpsi's Avatar
Doesn't matter really
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/crx-brake-bleed-order-2445548/
Old Feb 28, 2011 | 11:01 AM
MRN1120's Avatar
I told you, no need for brakes as slow as you drive.
Old Feb 28, 2011 | 11:10 AM
4drEF's Avatar
Keyboard Humorist
Nope. It's for all cars.
The car has 2 circuits - RP + FD and RD + FP.
It's a safety issue in case one circuit dies (line breaks, caliper dies, etc) then the other circuit operates on opposite ends of the vehicle and and doesn't send the car into a spin.
the idea is to bleed one circuit at a time starting with the circuit that has the longest distance to push fluid - the right passenger rear.
As opposed to doing both rears and then both fronts, the criss-cross method helps from pushing old fluid into the freshly flushed line of the first circuit.
Old Mar 1, 2011 | 03:33 AM
CWBETB's Avatar
But my sneakers are wearing out
Thanks for the help all
oramac_eg
16
Nov 14, 2008 02:55 PM
7808
16
Apr 12, 2007 04:48 PM
BmoreCivic
Jul 2, 2006 04:59 PM
enrique
42
Oct 25, 2003 07:56 PM
ViperRedCRX
Jul 1, 2002 02:10 PM
