Duel 77mm Throttle Bodies ????????
im running duel 77mm throttle bodies on my stock h22a and it will not rev up at all its like its in limp mode is it not enough fuel? will i have to get a tune? or is there a way to trick the map sensor and eacv? I guess its like running ITB's but i only have 2 throttle bodies any ideas????
duel is a fight. dual is two. the problem is grammar.
besides that ^^ what he said. you can't even run a normal setup(well) with no tune and your gonna try this?
well ive got it running perfectly with no upgrades just made a vacume box for my eacv and now it workx great and the throttle responce is freakin AWSOME!!! now i gotta get a h22 tranny and get rid of this long *** geared f22 tranny!!
Its running great with no tune!! i tricked the ecu by making a vacume box so it holds a constant air pressure! seems to be working great!
Now get it tuned..
and may i suggest a b series LSD tranny..
why do you say that!! i have it set up to where i only run one untill about 5500 rpms than the other starts to open.
and i am useing a f22 LSD tranny but cant seem to find the right axles they seem to bind up on turns!!! any ideas?
Your VE curve probably changed significantly when you installed that setup, so you should really tune it. If you can get a stable MAP signal, then at least you can keep your speed-density calibration and just alter your fuel and timing maps.
well i went to my local performance shop and they could'nt believe there eyes and said they have never seen anything like it but since i am still running my map and tps they can tune it!!! 400 for the tune but say i need bigger header also to let out as much air as im bringing in!
pics or gtfo haha i need to c how the heck that works do the tb's go where the plenom bolts i know the h23 has a 2 piece intake but not to familiar with the h series
booboo782
Engine Management and Tuning
Feb 3, 2014 06:28 PM
