h22 turbo build
Ok so i've had this h22 motor for a good while all ready. I got eagle rods, mahle low compression pistons, block gaurd, built head, golden eagle intake manifold, and fuel rail. So what i want to know is if i run this set up with stock sleeves how many horses or what 1/4 miles times will i be able to get out of this set up?? Someone please help me out.
You know we have a Forced Induction forum?
https://honda-tech.com/forums/forced-induction-16/
Find other H22 boosted build threads and read up.
Not hard to find. Go here.
and scroll halfway down the page. You've been a member for almost 2 years so I thought you might at least know your way around H-T.
Why would you lower the compression? lower compression = lower horsepower in both n/a and forced induction applications.
People have easily run 250-400whp on stock h22 blocks. It's all in the tune.
cause i was told that with less compression you can boost more and the motor i got had broken pistons
Leave the compression alone and get a good tune and you won't have to worry about reliability.
Good tune > compression.
Wouldn't be a bad idea to upgrade the rods and pistons if that's a concern. Lowering the compression is just going to hurt the potential of the motor whether it be n/a or boost.
Here's some ROUGH numbers for hypothetical arguments sake. Let's assume this is all the same trim turbo on the same engine with different compression ratios.:
7lbs boost 12.1:1 compression = 250whp
7lbs boost 11.5:1 compression = 220whp.
With lower compression you have to work harder for the same power.
But the tune has to be SPOT ON. Would you risk it? I've heard too many horror stories about crappy tunes and the damage that occurs. The margin for error in a tune gets smaller and smaller as the compression gets higher and higher. If you're tuner is not experienced with high compression nand boost then don't take the risk.
Less compression means less power. Period. It does make it safer to run higher boost, but that's pointless unless you're looking at 600+whp or something crazy. All lowering compression does is lower the margin of error when dealing with a bad tune. A good engine tune will be better for reliability than decreasing the engines capability just to boost it more.
well i have had the rods and pistons for over a 1 1/2 to2 years now still brand new in the box. and well i'm not really looking to make this car a dyno queen i want to make it a track car. so what i want to know is if i can get 10's or 9's in the 1/4 mile out of this motor setup i got on stock sleeves with a really good tune?
also forget to mentain that a built sohc for boost is going in this car before the h22 does. so the h22 is going to have to be faster then what the sohc will be. we're hoping to get 12's or 11's out of the sohc also on a really good tune.
depends who u gnna have tuneing...
i personally will boost a stock h22 on 7psi instead of lowering compression for same setup...
7psi sounds fair on a good tune
dont cheap out, bring it to someone around your area thats a great tuner!!
also i am looking to boost at lease 15+ pounds of boost and no lower. like i previously said this motor can not be slower then the turbo built sohc that is coming before the h22.
also the guy i got the h22 swap from had the h22 boosted and had it running 12's or 11's for only a coulpe of months until the pistons ring lands went out and broke. i don't want this motor to blow right away. i want this motor to last for a really long time
You do realize that 15lbs of boost is a magic number. 15lbs on one turbo would yield X results. 15lbs on another trim would yield Y results.
You're looking at running 9's? Have you got a parachute? Roll cage?
If you want to run sub 10second 1/4 miles you will not accomplish that with low compression OR stock sleeves. You're looking at custom differentials, totally rebuilt engine. Judging by this thread you're a bit over your head.
on the b note i already know what the nhra classifications for running 11's throw 9's is. i forgot to mention to you all that my dad has been doing drag racing for over 22 yrs. once you get in the 11's you need a 6or 8 point roll cage and once you get in the 9's you need a full roll cage, parachute, and window net
well thats why i came on here to ask you all if stock sleeves will hold up to want i want to accomplish but from what i can see they won't hold up. so thanks for the help
There's a thread on preludeonline, nearly half of all people running stock pistons blow the ringlands on low boost (5-7 psi), making around 250 whp
mhlamin
Jun 19, 2008 09:08 AM
