pb for the hatch
Old Feb 26, 2011 | 03:13 PM
350znal's Avatar
Default pb for the hatch
Mods: h22, intake, 2.25 exhaust, weight deduction(still has passenger seat) and dr's. Still dropping out of vtec on the 1/2 shift with the p13 installed.
Temp at the track was 66 degrees and 42% humidity.. da was 1044
60ft 2.174
no 330ft on slip
1/8 9.187
mph 78.66
1/4 14.194
mph 99.77
I have a bpi velocity stack, aem uego, rmf style header, 3in exhaust(no muffler) and a nitrous kit going on for next visit
Old Feb 26, 2011 | 05:17 PM
bauergold's Avatar
Default Re: pb for the hatch
Add some slicks to that list and you'll be golden.
Old Feb 26, 2011 | 05:21 PM
350znal's Avatar
It's on some 225/50/15 bfg dr's on some fat fives
Old Feb 27, 2011 | 01:05 PM
Desir Performance's Avatar
try and bring that 60' down and you should be golden.
Old Feb 27, 2011 | 02:26 PM
350znal's Avatar
That is what i'm trying to do is perfect the launch on these dr's and not break anything.
Old Feb 27, 2011 | 02:57 PM
RaceProfessor's Avatar
Are you preloading?
Old Feb 27, 2011 | 03:05 PM
350znal's Avatar
Yeah, always do.
Old Feb 27, 2011 | 08:45 PM
SIXTY-1HATCH's Avatar
**** yoll so it!! you have ALOt to do with that thing!!! We did anh22 hatch eg and stock ecu, with vafc. changed vtec alittle and retarded the dizzy and ran a 150 shot on it, may have been larger and the car went low 13's on street tires @ around 120+ mph. On the stock motor i think we were ALOT more in it!!! Have fun with the N20!!!
For sure borrow someone's slicks and run it on nitrous... youll be happy with the #'s for sure!!! have fune
Old Feb 27, 2011 | 08:49 PM
base-op.1320's Avatar
as stated get slicks
Old Feb 27, 2011 | 10:19 PM
Should be able to go 13.6-13.7's with that mph. Play with the launch rpm, preload and cut a 1.9 60 foot and you should be in that E.T. range.
Old Feb 28, 2011 | 05:14 AM
wolve's Avatar
eg hatch at 120+mph on streettires should do low 12's and easily mid 11's on slicks... def. has alot more in it on current power!!
OP: i see high twelves on motor and low 11-12's depending on shot size. h22 + nitrous is pure sex
Old Feb 28, 2011 | 03:08 PM
350znal's Avatar
wolve: what size shot are you spraying on that 12.3@119 run?
2k1 GSR
Nov 19, 2013 06:10 PM
H22AHatchBack
Feb 7, 2013 11:08 AM
SiR18EG
Feb 19, 2009 02:50 PM
ek_slut
Sep 16, 2005 06:05 PM
Hondasaurs
Jul 4, 2003 11:42 AM
