Feb 2011 FS Thread
Old Feb 1, 2011 | 05:47 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Feb 2011 FS Thread
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 1-1-2010, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings
Old Feb 1, 2011 | 05:54 AM
Big Teggie's Avatar
Default Re: Feb 2011 FS Thread
Contact Info
E-Mail – BigTeggie@gmail.com
PayPal - BigTeggie@gmail.com ADD 3% FEE to listed price if you choose PayPal
Please email and click on the thumbnails for larger images
RLZ All Motor K24 Short Block
- Assembled by Howard at RLZ
- K24A4 Block and Crank
- AEBS Sleeves
- IPS K24 Cunningham Rods
- RLZ Spec Wiseco Pistons (14.5:1 c/r & 89.5mm bore)
- ACL Race Bearings
- No accessories included
- All parts are brand new, zero miles (the block came out of a wrecked accord with less than 10k)
- I will not part out or disassemble, sorry
- Block at RLZ shop in NC. You can pickup in NC, get it shipped, or pickup in NJ
$3450 + Shipping
2003 K20A2 Shortblock
- Decent condition, I used this block with a K20A3 head to move the car around.
- Has some damage to one of the trans mounting holes, however everything still bolts up good.
- Good for a quick stock rebuild (Hone and Re-Ring)
- I will not part out or disassemble, sorry.
$400 + Shipping
Pictures to Follow
K-Series Quaife ATB
-Brand new, Installed into a transmission, however NO MILES
-Includes BRAND NEW OEM bearings and speedo gear
$775 Shipped
K20A Transmission Outer Cases
-Great Condition, One is from K20A2 and the other is a K20A3, both the same thing
$150 Shipped Each (1 Still Left)
Painless Master Disconnect
-Great Condition, like new
-Includes NHRA Approved shut off switch, and power wiring from the battery (located in front fender) to fuse box in stock location.
-Removes the need to run heavy gauge wiring from the front to back of car
-Everything is labeled and wiring has high quality crimp connections
$150 Shipped
Old Feb 1, 2011 | 06:05 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Selling a few things just because Im doing some changes in 2011 season
GE GSR manifold Fuel Rail and Manifold 430.00
Old Feb 1, 2011 | 06:18 AM
Kevin's Avatar
BRAND NEW NEVER USED Innovative/Hybrid Racing K series mounts for 90-91 Integra (also 92-93 Integra GSR). Custom ordered 95a hardness.
$300 shipped.
Old Feb 1, 2011 | 06:31 AM
redboost10's Avatar
b16a2 head:3000 obo or will part out cam/roller setup
portflow port/polish, valve job, etc
supertech 0.5 oversized valves including inconel exhaust valves
supertech heavy duty dual valve springs and titanium retainers
ferrea cam/roller setup
valve cover is polished with two -12an bungs welded for catch can setup
t1race golden eagle cam gears and bracket for cam trigger setup
hondata intake gasket
ill throw in about 200 bucks worth of spark plugs (denso ik27's) that i was using with the cbr coils.
upper tbelt cover has been trimmed for the t1 cam trigger bracket as you can see in the pictures below.
im sure im missing some things. pm me any questions.
this setup made 931whp on mustang dyno at 37 psi.
everything has about 140 miles on it total, including 8 dyno pulls, about 20 passes, and some low rpm tuning for drivability.
brad penn 20w50 oil only.
longblock was assembled by scott muongvang (hotrodteg) which im sure you northwest guys know.
car went 9.70's on about 28-30 psi, never saw more than 30 psi at the track.
Old Feb 1, 2011 | 06:36 AM
haas480's Avatar
full-race front mount turbo manifold. dual 44 gate outlets. t4 flanged.
$900
s372r. race cover. double bore front wheel ($200extra). 87mm turbine wheel ($300extra)
3" vband compressor outlet, 4" vband exhaust outlet
$900
1000hp spearco air-water intercooler, meziere pump, and water tank setup
$800
Turbosmart 50mm Pro-Gate BNIB
$400
slightly used eagle rods. gsr (87.2mm) stroke. $200.
'91 b16 head. cams, dizzy, vtec solenoid NOT included.
Old Feb 1, 2011 | 06:38 AM
hondasarethebest's Avatar
Motec Sdl backlit with datalogging unlocked $3500
Motec M4 with datalogging $950
A1000 Barely used ran out of fuel on dyno so replaced with eliminator $275
Brand new s372r .90 ar backhousing $125
Brand new set of 4 eagle d16 rods and 3 d16 used singles $300 for the set or $50 per used rod
Slightly Used Autometer 11k tach with recall $150
Used Progress shocks and springs not sure on spring rates $400
Old Feb 1, 2011 | 06:46 AM
FIxALPHA's Avatar
Brand New Edelbrock 70mm throttle body w/two gaskets and 70mm spacer/adaptor - $300 Shipped
Quaife GSR LSD. Brand New in Box (No Pic) - $700 Shipped
Recaro SRD's - $800 Firm. Pick up preferred. Central NJ
Driver Seat: Black SRD w/sliding rails for eg/dc chassis.
Passenger Seat: Confetti SRD w/sliding rails for eg/dc chassis.
Great Condition - No Rips - No Fades
Please bump if viewed. Thanks!
RCI harness bolted on. Too lazy to take it out for the pic. Wire harness so you can plug it in to the stock harness. No red seat belt light.
Serial Numbers
Passenger Seat
Old Feb 1, 2011 | 07:04 AM
E Town DSM's Avatar
**************************** New Low Prices*******************************
Manley Turbo Tuff Rods For LS Crank with New ARP Custom Age 625 Bolts. Very little use about 15 passes on them. Bolts are brand new Bolts alone cost 250
Asking $800 for rods\bolts shipped will seperate if need be.
t4 top mount divided\twin 44mm manifold for b series - $725 shipped
Edelbrock 4730 B-Series Cams Intake 288dur\.490lift Exhaust 266dur\.454lift(No Longer Made By Edelbrock) great upgrade for turbo car or mild all motor setup. Picked up 35whp over type r cams on a turbo car. -380 shipped
c02 setup for a boost controller includes regulator, bottle,mount, larger fill station with transfer hose pm me for details
Email Juice2435@aol.com
Old Feb 1, 2011 | 08:25 AM
locash's Avatar
Need funds to pay for the engine harness for my race car, so selling this stuff might cover part of it.
AEM Series 2 (part number 30-6040), new in box, fits Honda/Acura with OBD1 ECU plugs. $950 shipped in the continental US.
joe@locashracing.com for more info.
Old Feb 1, 2011 | 09:33 AM
Garage 808 Hatch's Avatar
empty
Old Feb 1, 2011 | 12:30 PM
gogetta's Avatar
Innovative Solid Mounts - $200 Shipped These have the 90A bushing/or will trade for Pure Aluminum solid mounts
Injector Dynamics 1000cc injectors $400 Shipped Sold!!!!
Precision 750hp Intercooler w/ 3in inlet & outlet Polished - $365 Shipped Sold!!!!
AEM fuel Pressure reg Blue - $60 shipped
AEM Feul rail Silver - $60 shipped
B&R Fittings filter to rail kit black line and fittings for AEM rail - $40 Shipped
While let all fuel parts go for $150 shipped if purchased together.
NX Express Direct port setup. Includes whats pictured only. $75 shipped SOLD!!!!!
Garrett Gt4294 turbo - $550 shipped "Pending to turbointegra750" SOLD!!!!
Offers and Trades are welcomed
AEBS B18C1 84mm sleeved block Fresh bore and hone - $475 shipped - needs work
Update!!
Had 15 inquiries about the block so.....
Block has stripped bolt holes on the transmission side that are plugged with helicoils. It will also need an align hone, because the machine shop misplaced the original main caps. All can be fixed at any machine shop
Included:
maincaps
Gsr girdle
timing belt tensioner
water pipe
anything else pictured that i might have missed
Old Feb 1, 2011 | 12:36 PM
EDLOVA23's Avatar
IF INTERESTED CALL 973)390-2982
SKUNK2 B-series tuner 1 $450 obo
PRECISON intercooler $300
AEM ecu obd1 1040 box $850
intercooler dimensions 31x10x3.5 these are the only pics i have
Old Feb 1, 2011 | 01:02 PM
SPOOLINmatt's Avatar
ARP Head Studs
GSR B18C1....Also works with LS VTEC setups
Torqued a few times, just upgraded to stronger studs for the hell of it...these still hold just fine.
65$ shipped.
GReddy Oil Sandwich Adapter
USED, Comes with orings, -6 fitting, Honda oil filter center fitting. Great for an LSVTEC or TURBO setup for feed line or Both.
$40 Shipped
Old Feb 1, 2011 | 02:06 PM
jody754's Avatar
MSD digital 6, blaster SS coil, noise filter and H22 distributor cap only 300 miles on set up $250
Old Feb 1, 2011 | 02:31 PM
jdm inc's Avatar
tial red bov 200 shipped
-4 Size oil inlet fitting for GT Ball Bearing Turbos for GT28R/GT28RS/GT30R/GT35R with built-in oil restrictor (of .035" hole size). Custom machined part. Output is -4 AN male flare. use with any of our -4 feed line assemblies 20 shipped. brand new never used.
Old Feb 1, 2011 | 03:50 PM
JDM JEFFREY's Avatar
custom dash for 95 civic
comes with
tuner view with hondata converter
shift light and auto meter tack
275.00shipped +paypal fees
vis carbin hatch 1 year old very clean
350.00shipped +paypal fees
Old Feb 1, 2011 | 04:15 PM
sohc95vtec-t's Avatar
-used NOS nitrous setup, with plate setup for a GSR.. plate bolts in place of the factory butterflys on stock mani.. really nice setup
-more info on the setup: http://www.hawkinsspeedshop.com/cate...duct-1280.html
-$300 shipped/paypal’d
-used AEM FPR for d series (?)
-SOLD
http://i4.photobucket.com/albums/y10...e/P7300392.jpg
http://i4.photobucket.com/albums/y10...e/P7300393.jpg
BRAND NEW skunk2 70mm throttle body for B/D/H series
$250 shipped/paypal'd
AEM FPR for B series, great condition, with -6an return fitting
$85 shipped/paypal'd
BRAND NEW JRSC fuel pressure regulator relocator (rotates the FPR to clear different setups)
SOLD
http://i4.photobucket.com/albums/y10...e/2d2d6e40.jpg
Old Feb 1, 2011 | 04:38 PM
BlueByYou's Avatar
str manifold for gsr $300
intercooler $400
2-turbonetic turbos t66....$600 each
spec clutch - *****sold*****
used wastegate..$100
custom manifold for t4 turbo...$900
used head pr3-3....$400
used wastegate....$100
88 crx rolling chassis, roll caged and fiberglassed...$4000
Old Feb 1, 2011 | 05:30 PM
AROD's Avatar
TurboElements Topmount Manifold T4 = $600
Autometer tach with shiftlight =$ 70
Civic or integra 4" downpipe 4" aluminum full catback system with Mangnaflow 4" muffler = $350
AEM UEGO system =$ 125
Call 518-588-7193
Old Feb 1, 2011 | 05:36 PM
Topdawgg's Avatar
Quartermaster 5.5 Carbon/Carbon Twin Disk w/ B-series flywheel
Clutch needs one disk replaced, should be around 350-400$ direct from Quartermaster.
Reason for selling is that I picked up a Cerametalic Tilton unit. The quartermaster is too much clutch for me right now.
Paid 2000$ for this from Franklin @ Avid a while ago, has a few dyno pulls on it after I bought it.
NO REASONABLE OFFER will be refused!
could use ANY cash right now to get my car where I want it this year!
(clutch is identical to the one in this picture)
Also for sale, TurboXS Quad Stage boost controller
150$ OBO
Old Feb 1, 2011 | 05:37 PM
boosted hybrid's Avatar
T1 Web Pro camshafts with extended rocker pads. These are the same Web Pro cams that Tony1 runs in his engine. Brand new, never used. Will include the T1 billet vtec block off plate that is brand new. $2000.00 shipped. No wait time, save hundreds!
Custom 15x11" Bogarts with double ultra lightweight beadlocks. These are the R/T 4 spoke with black anodized centers, 4.5" backspace and a brand new set of M/T 26x10 slicks mounted and balanced. Also includes metal valve stems. These will clear the factory knuckles with no grinding/cutting. Waited months for these to be made, and spent $2300.00+. $1800.00.
Kenne Bell Boost-A-Pump Competition 20 volt dual fuel pump controller. This is the top of the line Kenne Bell Boost-A-Pump that controls 2 fuel pumps. Its the competition version that outputs 20 volts to the fuel pump! Even if the battery is at 9~10 volts this keeps the fuel pumps at a constant 20 volts! This is key for drag cars using a standard 14 volt system. I used it for start up on my drag car, but going another route. It has maybe 1 hours of "running" time that really consists of just idling and free revving. $350.00 shipped in the 48 states.
Old Feb 1, 2011 | 06:26 PM
johnls's Avatar
hey whats going on i got a turbonetics t4 62 mm turbo for sale it in good shape reason for selling was to upgrade to a bigger turbo. it has a 3 inch vband exhaust housing i would like to get 500 obo for it i can ship if i need to you can pm me with any questions thanks
Old Feb 1, 2011 | 06:47 PM
Allmotor B20's Avatar
k-series Hasport solid mounts $500
2 sets of K-series driveshaft shop axels 3.9s with a set of hubs one set is brand new still in the box $1600 obo
DTR SSR 4-1 header with megaphone $1100 obo
Weld wheels painted black 15x8 with mt 15x8x26 they have 10passes on them $1100 obo
Rear Kens Kustom Trailing arm with Strange shocks 80lb springs and gold Weld wheels with almost new tires $2800 obo
Front penske shocks with resevoirs $800obo
Skunk2 upper control arms $150obo
Kens Kustom single wheel wheelie bars $700obo
Front lower control arms with custom solid bushing $120obo
Custom carbon fiber one piece front end $1200 obo
Franks Custom fiberglass doors modified window frame for ef with door pins needs a little work complete with hardware $500obo
pro stock wing $300
buyer pays shipping
or rolling chassis for$5,000obo
Old Feb 1, 2011 | 08:42 PM
9seccivicsi's Avatar
b16 Pr3 head 250 obo
sparco speed seat 150
Bdl cam gears - 150
Bdl fuel rail- 100
prices do not include shipping.
