My ek hatch has a sunroof -_-
Old Feb 25, 2011 | 01:57 PM
JDM809's Avatar
Default My ek hatch has a sunroof -_-
I bought my 98 Civic DX hatch about 2 years ago. The old owner had an aftermarket sunroof installed. Now 2 years later I am going to start a turbo project with it and I am in search of ideas to get it replaced. Getting a new roor is pretty expensive. I tried looking into the cf sunroof plug kits out there but they only make them for the oem diameters. Anyone have any pics or other ideas of what they have done to take care of this. Im thinking maybe plexiglass. The car will mostly be out on weekends or on drag events.
Old Feb 25, 2011 | 08:12 PM
JDM809's Avatar
Default Re: My ek hatch has a sunroof -_-
Anyone?
Old Feb 25, 2011 | 10:13 PM
gorillafart's Avatar
other then the obvious, replace the roof skin, with say a used one or aftermarket one? get a full roll cage and it wont matter what you do to the roof.
Old Feb 26, 2011 | 12:04 AM
JDM809's Avatar
I might just leave it. Not going to bother spending money on that. I can use that money on my motor. If I figure something out though ill post up pics....
Old Feb 26, 2011 | 05:35 AM
ken9's Avatar
I thought the samething too--^ If is costly to do a sun roof then it isn't really worth it unless you can find a good deal and doing it right..
Old Feb 26, 2011 | 09:29 AM
JDM809's Avatar
I bought my hatch this way. Im trying to get rid of it not get one put on.
Old Feb 27, 2011 | 06:16 AM
JSPECSIR's Avatar
well you have one advantage, an aftermarket sunroof(once removed) is not going to have a pinch weld fold around the opening. if you could find say an old carbon hood that was damaged if it had a large enough area of flat carbon that was ok, you could cut out a piece larger than your opening and use smc to metal panel glue and adhere it to the bottom your roof skin just as the sunroof is now. instant carbon block off plate.
nitrousballa45
Jan 15, 2016 06:02 PM
TWOLITREmedia
Appearance Build Threads
91
Mar 30, 2015 06:25 AM
Dyln.bxtr
Jan 30, 2013 07:29 PM
ekstance
Nov 28, 2011 03:33 PM
mrtrex
Jun 30, 2004 08:43 AM
