jumping tach?
Old Feb 23, 2011 | 08:26 AM
dc4teg95's Avatar
Default jumping tach?
So I got a little issue with my each. When driving normal its fine but when im getting on it hard and take it to recline the each begins to jump when it gets to about 6 then shoots to 7500 then way down to 9+. What could cause it to do this. Before 6 it will climb like normal when racing but after 6 it begins shooting to higher numbers. Any ideas on what causing this? I have no codes
Old Feb 23, 2011 | 10:30 AM
1998GsRIntegra's Avatar
Default Re: jumping tach?
Check your igniter. ONe of the leeds off it feeds the tach.
Old Feb 23, 2011 | 12:16 PM
Mattb16teg's Avatar
Community Builder
Community Influencer
Possibly the igniter, possibly the wiring going into the pins on the dizzy harness or an issue in the main engine harness.
Does it missfire when this occurs?
Old Feb 23, 2011 | 02:05 PM
dc4teg95's Avatar
Ill try the ignitor. Car pulls hard and strong just the each goes crazy after 6. No misfiring. Only other issue with the car that may be related is the car surges up and down after reaching op temps when im idling. Eventually stops if im sitting long enough. I cleaned the iac and that seem to help some soesnt surge as much but still does it once in awhile.
Old Feb 23, 2011 | 04:48 PM
What year is the motor? If it is old enough to have an FITV clean it.
Old Feb 23, 2011 | 06:02 PM
dc4teg95's Avatar
The car is a 95 but the motor is a obd2 itr swap so no fitv
Old Feb 23, 2011 | 07:54 PM
92_DB2's Avatar
+1 on igniter it happened to me. Fix it before it breaks
Old Feb 24, 2011 | 05:08 AM
dc4teg95's Avatar
Is there anyway to check it with a volt meter. I have a spare one that ima swap in any way but just wondering if there is a way to check it
Old Feb 24, 2011 | 09:30 AM
I dont know if there is a way to check it. I guess you would have to figure out which leed feeds the tach. Maybe you could check from there? I have never been good with wiring.
If you have a spare to swap in then just do that. If it fixes the problem then the igniter was bad. Self explanatory, but yea. Lol
doson208
Jan 11, 2015 06:50 AM
Snail Tuning
Feb 8, 2009 05:09 PM
boostedteg15
Aug 4, 2006 06:55 PM
OneThirtyEight
Jan 10, 2005 06:05 AM
Ben-VTEC
Mar 23, 2003 02:22 PM
