d16z6 motor swap
Old Feb 21, 2011 | 05:19 PM
92lxsleeper's Avatar
Default d16z6 motor swap
just did my swap and wouldn't you know it, the rod bearings are spun.
they are fine at idle, but it makes noise at 2000 rpms and up, so saturday i get the joy of pulling the pan and replacing them.
any writeups on this?
Old Feb 21, 2011 | 05:21 PM
CPreston's Avatar
Default Re: d16z6 motor swap
youre gonna have to measure the crank and stuff to make sure its still within spec or replacing the bearings wont help.
Old Feb 21, 2011 | 05:28 PM
numberone's Avatar
Check the journal to make sure it is within clearance specs. If not, you will have to get it polished. Was it scared?
Old Feb 21, 2011 | 07:29 PM
not sure yet. i havn't pulled the pan. im waiting till saturday when i get the day off work. im hoping that they are just slightly spun like my ls to where they aren't outta spec yet. if they are then ill just part the car out and im thinking of financing a 2000 accord 3.0 vtec.
Old Feb 22, 2011 | 05:04 PM
honda on the go's Avatar
I just did a d16z6 motor swap and was wondering if you know why it would be makeing a nosie it sounds like a whining noise. cant figure out where its comeing from someone told me that it might be the air con belt but sounds likt comeing from the motor any help?
Old Feb 22, 2011 | 05:12 PM
HondaPartsHero's Avatar
Technical Hero
did you change the timing belt? If its overtensioned it could make this noise as well.
Old Feb 27, 2011 | 02:08 PM
well yesterday i ripped the bottom end apart and low and behold, cylinder 1 had a spun bearing. so i hacked it and just threw a set of bearings in connecting rod 1 and threw it back together. i know i should have had the crank cut and replaced the mains, but i dont have time to wait for that, or the money either. so it looks like im saving all my money til either it blows up, or until april when i try to finance a 2000 accord.
Old Feb 28, 2011 | 07:53 PM
so i drive it to work and back today and it was knocking again. so i said F it and i sold it. now i have no car, and i'll be looking for another one.,
Jdm03
Aug 24, 2011 04:56 PM
Crashtestdummy
May 9, 2011 12:41 PM
Demerica333
Nov 14, 2010 04:56 AM
kyalstyle
10
Nov 2, 2008 09:19 AM
nicks-eg6
Southeast (Sales)
Mar 12, 2008 04:16 PM
