eg cluster help!!!!!!! plzzzzz
ok here is the problem... on the back of the cluster there is some screws you could tighten up or loosen up!
now what i need to know is how tight or loose they have to be for each/???
i need to know this guys if you could plz help i would really appreciate it!
thanx
thanx
temperature has 3 srews!
+ ( how loose or how tight?)
- ( how loose or how tight?)
T ( how loose or how tight?)
fuel
F ( how loose or how tight?)
speed tach
S ( how loose or how tight?)
rpm tach
fuel
speed tach
rpm tach
tight is tight, broken is too tight..
its thin plastic, just tighten them real snug. i dont think any of those screws hold any needles in so i wouldnt worry about it too much
ok here is the thing. they where all tight so when i started my car in the morning which was cold the temp went pass hot. so i was messing with the temp + and - and the needle would wither go to very hot or cold but if it was in cold it stayed there even though my car is warmed up
I just had a similar problem with my cluster,get a new one its much easier,i found one with a rpm tach for 15 bucks at a junkyard, i did it for piece of mind lol
Too tight bro... I did the same thing to my gas gauge. If you are lucky, you wont need to buy a whole new cluster, just look around, some people will just sell you the specific part (fuel, temp...) You just want it snug, not to tight. The screws complete the circuit and if it is too tight, the current wont pass.
i will try to loosen it a bit
and if not im looking for a cluster
ej2kiid
22
Jul 14, 2011 12:24 PM
NinetyTwoHB
14
Oct 31, 2005 09:45 PM
dohc boy 96
Aug 1, 2003 02:41 PM
no cash right now!
