HOPE SOMEONE CAN HELP ME
Old Feb 19, 2011 | 03:39 PM
JDMeFBOI's Avatar
Default HOPE SOMEONE CAN HELP ME
jus bought a 88 hatch..its converted to obd1 with a dohc zc..it starts but when i give it gas it bogs out an turns off..what could it be??? i changed the wire harness an injectors already..
Old Feb 19, 2011 | 04:06 PM
th3pwn3r's Avatar
Default Re: HOPE SOMEONE CAN HELP ME
I'd check plugs, wires and fuel pressure before all else.
Old Feb 19, 2011 | 04:19 PM
JDMeFBOI's Avatar
i wired the fuel pump direct to the battery jus to make sure an its throwing fuel fine..the plugs are fine to i checked those..anything else u recommend??
Old Feb 19, 2011 | 04:28 PM
KINGVEM^^ED6's Avatar
dizzy
Old Feb 19, 2011 | 04:34 PM
JDMeFBOI's Avatar
thats fine to...would it better jus to get it all rewired up???
Old Feb 19, 2011 | 07:59 PM
hatchet_honda's Avatar
88 what? dx? si? if this car was converted from dpfi to mpfi perhaps the 2 wires on the tps were not switched. the red wire and green wire should be switched around
Old Feb 19, 2011 | 08:58 PM
sde780's Avatar
check your timing (ignition and mechanical)
Old Feb 19, 2011 | 09:30 PM
Goldo6606's Avatar
sounds like ur throttle aint responding..not enough air getting into the cylinders
Old Feb 19, 2011 | 09:34 PM
orr sounds like the tps is wired wrong...
Old Feb 19, 2011 | 11:47 PM
JDMeFBOI's Avatar
its a si..I will have my homie check out the tps wires...and the timing is koo it starts an idles fine jus when i give it gas it boggs out
Old Feb 20, 2011 | 06:20 AM
sde780's Avatar
it'll start fine with the mechanical timing being off, but once you try to make it up a hill at 3k rpms it will bog. this was with the timing belt 1 tooth off
Old Feb 20, 2011 | 06:46 AM
OddityDX's Avatar
I had a similar problem. Turned out to be the fuel filter.
SF_Dee
Jun 23, 2010 07:07 PM
lsvtechatch92
Jun 25, 2007 03:03 PM
EGk3nrock
Feb 8, 2007 03:39 PM
pokemon
May 4, 2003 02:02 PM
BrownGSR
Apr 2, 2003 10:30 PM
