heat wrap - yay or nay?
Old Feb 16, 2011 | 12:30 PM
boostedBLUfg2's Avatar
Default heat wrap - yay or nay?
i just got my new manifold and downpipe in.
i'm planning on ceramic coating the manifold due to the complexity of wrapping it - tons of bends and whatnot, would be awkward to wrap.
with the downpipe, I was planning on just wrapping it with some DEI thermal wrap and calling it a day. i dont' really want to ceramic coat it because it's hella expensive and i'm quickly running out of money.
however, I was told recently by a friend that wrapping it will cause hot spots on the downpipe, causing warps. not only that, but it will corrode much faster, and possibly make the stainless steel brittle over time. is this true? should I not wrap it?
Old Feb 16, 2011 | 12:52 PM
anavrin's Avatar
Default Re: heat wrap - yay or nay?
Hmm my setup is the same right now ceramic coating on mani and dumptube but my
Downpipe is wrapped haven't heard of the whole hot spot thing like to know this iinfo as well
Old Feb 16, 2011 | 02:56 PM
BLU CIVIC's Avatar
Track Advocate
i wrapped my downpipe with DEI titanium wrap.
on their site, regarding the titanium wrap, DEI recommends spraying the pipe with silicone spray if you're using a steel pipe, then wrapping, to prevent possible rusting. but i've never heard of heat spots or warping.
Old Feb 16, 2011 | 04:51 PM
94VTEC2TONE's Avatar
why not just hottemp it, looks a hell of a lot cleaner than any wrap job
Old Feb 16, 2011 | 06:41 PM
it's pricey. the manifold alone is $150. I'd probably be looking at another $100+ to do the downpipe, and $50+ to do the dumptube, whereas i already have some dei titanium wrap lying around to use ya know?
Old Feb 17, 2011 | 03:31 AM
93lsv_turbo's Avatar
Dude ive seen a few wrapped manifolds on here that have looked clean as hell. You juss have to take ur time and wrap it tight. Im getting my manifold and downpipe ceramic coated and wrapped. I live in a hot humid area so I want all the help with underhood temp I can get
Old Feb 17, 2011 | 04:05 AM
spoolinlude's Avatar
I live under a rock
Heat wrap works great, although I don't recommend it for steel if your car is a DD, the moisture and dirt the wrap holds will definitely rust your system faster than normal, especially if salty road water gets into it. If your car is not a DD (doesn't see rain), then heat wrap all the way. If everything is stainless, I would wrap it and be done.
Old Feb 17, 2011 | 04:45 AM
LS AzZkIkr's Avatar
I highly recommend anything to lower temps under the hood. Turbo blankets, coatings, wraps, and ect. If you are worried about wrapping your DP and have it rust/fail then scuff it up and coat it yourself with the ceramic paint from the auto store then wrap it. Be sure to prep and prime the surface very well though so you don't have any chipping.
I started with wrapping my DP. That lead to getting my manifold, waste gate, and turbine housing coated. Now I recently got a turbo blanket and all this is a great improvement. My valve cover is giving off more heat than the turbo.
Old Feb 17, 2011 | 07:03 AM
s13silviaguy's Avatar
wrap it up... anything that cools the temp helps
Old Feb 17, 2011 | 07:27 AM
sanman000719's Avatar
and a turbo blanket
i say yahhhhhh whaaaaat
Old Feb 17, 2011 | 08:43 AM
yep, I bought a ptp blanket already from some suggestions on here. think I'ma just paint the header with some high temp paint then wrap it to avoid any corrosion to the surface of it. hopefully a nice, tight wrap along with coating the wrap afterward will leave it moisture-free
Old Feb 17, 2011 | 09:21 AM
BLU CIVIC's Avatar
Track Advocate
you don't need to coat dei titanium wrap
Old Feb 17, 2011 | 04:58 PM
im still going to anyways. better safe then sorry
Old Feb 17, 2011 | 05:01 PM
BLU CIVIC's Avatar
Track Advocate
i'd email DEI and ask them if it'll hold. by looking at the titanium wrap vs their regular wrap it's a big different in texture.
Old Feb 17, 2011 | 05:35 PM
The big difference between the titanium wrap and the reg. wrap is the titanium u dont have to soak and holds ALOT more heat
Old Feb 17, 2011 | 05:44 PM
boostingcivicSi's Avatar
I have my downpipe wrapped. It's definitely worth it, there are always drawbacks, but the pros are always worth it.
Old Feb 17, 2011 | 06:12 PM
96 GSR-T's Avatar
I wrapped my old ramhorn and dp in reg DEI wrap and I sprayed it with their Insulating Paint, I was very impressed no more smelling my flesh burning on the manifold after I accidentally brushed it with my hand and my underhood temps went way down... if it was coated it would still be hot as hell to the touch without the wrap from my experiences.
D15Bbigred
Apr 7, 2007 09:42 AM
opto_isolator
Jul 31, 2004 10:14 PM
Boost2NA
Jul 25, 2002 04:46 PM
yellowbulbs
Jul 25, 2001 02:19 PM
