what are these bolt numbers? Lca
Old Feb 15, 2011 | 06:33 PM
Daproject711's Avatar
Default what are these bolt numbers? Lca
What are these bolt part numbers or name when i search it alot of parts come so id like to be sure on what they are before i order them for Online.
just wondering are these it?
90172-SK7-A01 BOLT, DAMPER (LOWER) (10X84) 1998 INTEGRA
90173-SR3-003 BOLT, ARM TORQUE (LOWER) (10X80) 1998 INTEGRA
[IMG][/IMG]
Old Feb 15, 2011 | 07:53 PM
DKYamada's Avatar
Default Re: what are these bolt numbers? Lca
why order them? Is their any reason you need them brand new? you should be able to find any of those bolts at a local pick-in-pull.
Old Feb 16, 2011 | 06:02 AM
fcm's Avatar
fcm
Old Fart
http://acuraautomotiveparts.org/acur...s=&view=normal
http://acuraautomotiveparts.org/acur...s=&view=normal 94
Old Feb 16, 2011 | 06:06 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I'd probably order them new. Maybe the OP doesn't have a "pick-n-pull" near by, or maybe he doesn't have the time to try to go find used ones. To me it would be worth the time savings to just order new ones.
Old Feb 16, 2011 | 08:46 AM
DKYamada's Avatar
true, i was just throwing it out there to help maybe save him a few bucks.
Old Feb 16, 2011 | 09:18 AM
Community Builder
To answer the OP, yes those are the correct part numbers.
Old Feb 16, 2011 | 12:05 PM
dont really have a shop close to me. thanks tho
Thanks man!
Old Feb 16, 2011 | 05:48 PM
Alright i got the right side bolt but the middle bolt i dont seem to find the middle and cant find out where it screws on to.
Old Feb 17, 2011 | 08:03 AM
Function7's Avatar
Protip:
Do the middle one first (the one that connects to the shock) then do the end one.
Problem you're having is the holes are misaligned on the center one.
Old Feb 17, 2011 | 09:05 AM
masis1221's Avatar
how would u cut the last one > 9 the one close to the tire
Old Feb 17, 2011 | 12:10 PM
fcm's Avatar
fcm
Old Fart
What do you mean cut it?94
Old Feb 17, 2011 | 12:19 PM
Community Builder
I usually bolt up the shock fork bolt, then use a jack to raise the LCA into place, and then work the trailing arm so that it lines up with the outer hole. Sometimes it can be a PITA but eventually it lines up and the bolt goes in.
Old Feb 18, 2011 | 01:26 PM
you would get an angle grinder and grind it off thats what ive done.
integral94
Oct 6, 2006 01:17 PM
OneDirection
Suspension & Brakes
13
Jan 17, 2005 07:19 AM
smoke3
Jul 2, 2004 04:40 PM
flip b18b
Jun 28, 2004 10:31 PM
