results from compression test whats the next step?
so my compression was starting with the cylinder on the driverside and the last # being the far left on the pass. side 150-160-130-160. all are in spec 184psi max 135 min. but not withing 28psi from the highest # to the lowest. What do i do next? not sure if its my rings or valve seals that need replacing
re-do the compression test but poor oil into each cylinder before the test, if compression rises its the rings. if not its either going to be the valves or headgasket.
its not the head gasket, its brand new and the head bolts are brand new. Im going to do the leak down test and see whats up
SilkyJohnson
13
Feb 15, 2011 05:54 PM
turbosivtec
May 24, 2009 04:33 PM
humboldt_skim
May 31, 2008 08:18 AM
