1988 CRX DX, Fuse 12 (15A) keeps blowing
Old Feb 13, 2011 | 12:22 PM
atto's Avatar
Default 1988 CRX DX, Fuse 12 (15A) keeps blowing
Fuse 12 is listed as cig lighter, dome lights, and interior clock. As soon as I put a new fuse in, it blows.
Any ideas where I should start?
Old Feb 13, 2011 | 03:03 PM
jdmxefxsi's Avatar
Default Re: 1988 CRX DX, Fuse 12 (15A) keeps blowing
get ur car manual and locate the fuse on the schmatic and look for the wires coming in and going out of were the fuse goes.. check for shorts, cut wires etc..
Old Feb 13, 2011 | 03:26 PM
atto's Avatar
Sounds good, I hope I can locate it without too much trouble cause a lot of wires are wrapped into bunches with electrical tape. Thanks!
Old Feb 13, 2011 | 09:02 PM
killa69er's Avatar
clock, radio, cig lighter,trunk light, and dome is on 12. i just had this same problem
stock or after market radio? anything in your cig lighter?
pull the wires on each componet and install fuse if it blows go to next item on list
if it doesnt blow look for you promlem in that set of power wire see image for help
Old Feb 14, 2011 | 09:32 AM
atto's Avatar
There is no bulb in the dome light (can anyone tell me what size it is?), the radio (aftermarket Sony) doesn't work, the cig lighter doesn't work, and I don't think the trunk light is functional either (when is it supposed to turn on?).
Thanks! This will make finding the problem much faster... I'll report back once I find out what is wrong.
Edit: The clock works but the time resets after the car is turned off.
Old Feb 14, 2011 | 10:33 AM
killa69er's Avatar
the clock reset because the fuse 12 is a hot at all times.. and acts as a memory for the clock and radio...
non will work as long as the fuse is blown
i would say pull the radio and check the yellow wire on the back of the radio as that is the constant power to the radio the red wire is the acc. so when u turn the key on the radio turns on... if the yellow is off and hitting a ground u will pop fuse factory color on the car i belive is white with blue strip.
Old Feb 14, 2011 | 10:48 AM
atto's Avatar
What is "acc" for the red wire?
When you mean "hitting a ground", do you mean the insulation could have been worn and be hitting a piece of metal?
I will probably be working on it the day after tomorrow because I'm swamped with school work right now.
Old Feb 14, 2011 | 01:42 PM
killa69er's Avatar
the red wire on the back of the radio or the white and blue strip on the chassie harness could have bare metal and hitting something metal in the dash and grounding out..
same goes for the cig lighter as well and the clock fuse 12 is the white and blue strip wire curcuit
acc is for accessory red wire on back of radio
yellow is constant should have power all times
Old Feb 14, 2011 | 02:29 PM
atto's Avatar
Thank you for the clarification.
What did it end up being in your case?
I'll report back when I find it.
Old Feb 15, 2011 | 11:45 AM
atto's Avatar
I checked it out today.
I removed the console and I noticed a black wire (ground) from the radio just hanging (not attached to anything). I figured since it wasn't grounded, then that might be causing it. So I grounded it and put a new fuse in and it popped.
I then unplugged the radio and then put a new fuse in. It popped, too.
I unplugged the cig lighter and put a new fuse in. It also popped.
I followed the white/blue wire as much as I could but it is mostly wrapped in a black wire tubing, so I doubt that it's cut along there.
Red acc. wire is hot, but the yellow wire is never hot (even when motor is on). Could this be causing it.
Where should I go from here?
Old Feb 15, 2011 | 03:43 PM
codybuRr's Avatar
can u tell me where u got this diagram from?
Old Feb 15, 2011 | 04:14 PM
killa69er's Avatar
i have alldata
Old Mar 25, 2019 | 11:49 AM
Efmysedan's Avatar
Has anyone since this threads last entry solve a fuse #12 problem? And how.
I have this issue
Bringing threads back from the dead happens when people go to google before starting a new thread.
Jettplane
Sep 21, 2012 07:06 AM
xkrntamax
Honda Civic (2006 - 2015)
May 6, 2009 06:27 PM
H.
Audio / Security / Video
Aug 24, 2006 10:19 PM
sashimi
Jun 6, 2005 05:41 AM
green98civic
Apr 18, 2003 12:31 AM
