1993 v-tec del sol was runing then shut off and turns over but start please help!!
Old Feb 11, 2011 | 06:36 PM
jason ontiveros's Avatar
Default 1993 v-tec del sol was runing then shut off and turns over but start please help!!
help
Old Feb 11, 2011 | 06:39 PM
Wrona's Avatar
Default Re: 1993 v-tec del sol was runing then shut off and turns over but start please help!
Sparkplugs, injectors, distributor?
Old Feb 11, 2011 | 06:48 PM
EJ8_Man's Avatar
Probably your fuel filter is clogged.
Old Feb 11, 2011 | 07:23 PM
those are all in good shape. do u think the timing belt went
Old Feb 11, 2011 | 07:27 PM
92shade's Avatar
a compression test will tell you alot about your problem try that then check for fuel and spark
Old Feb 12, 2011 | 10:44 AM
EJ8_Man's Avatar
Don't waste time with a compression test. Check you're fuel filter/fuel pressure. Unbolt the top bolt on the fuel filter, turn the key to the ON position and check that the fuel pump is supplying fuel to the motor. If it doesn't come out at all your fuel pump is dead, if it oozes out your fuel filter is dead, if it comes out like a fountain then both filter and pump are fine.
Pull the plugs out and check for a spark while cranking the motor. If you have a spark on all cylinders that will prove its not the T-belt
You can also check if it was the timing belt, have someone crank the motor and look down the oil fill hole in the valve cover. If you see the rocker arms moving it's not your T-belt.
Check your basics... Do you have Spark? Fuel? Fire?
Old Feb 12, 2011 | 11:40 AM
EFPhilly's Avatar
http://www.askmehelpdesk.com/cars-tr...post-9924.html
just google search. Was trying to find the link I used...I though it was in the FAQs section but it wasnt. Gives a list in order of things to check. This topic has been covered 1000 times so search.
Also you gave no information on what happened, mileage, compression, nothing. just a help.....
Old Feb 12, 2011 | 11:42 AM
EFPhilly's Avatar
here we go:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%2A%2A%2A-basics-no-start-diagnosis-101-%2A%2A%2A-1992733/
http://www.hondacivicforum.com/forum...ad.php?t=74362
DelSol-B18
21
May 23, 2012 04:59 PM
Champs32
10
May 25, 2010 06:14 AM
jdm mini me
11
Mar 28, 2010 05:22 PM
krazie1
Oct 29, 2003 10:58 AM
civicspeed77
May 27, 2003 12:13 PM
