Engine mounts????
I wanna change all my engine mounts but not sure how to check if each one is bad or not. my car vibrates like crazy from the inside. for example if i put something in the glove compartment it will vibrate. what should I do?????
An 'easy' way to check is to pop the hood and have a friend rev up the motor a little. Look at the mounts and see if there is any unusual cracking and flexing in them.
Put the car in gear and blip the throttle while holding the brake pedal. If the engine moves forward when blipping the throttle in reverse, then your front motor mount is bad. If it moves backwards when in first gear or drive, then your rear mount is bad. You're gonna have to get someone else to look at the side mounts to see how much they move to determine if they're bad or not. The transmission mounts are usually never bad, but the driver's side engine mount goes bad pretty frequently. The rear mount is the one that goes out most often.
I don't want to sound like the harbinger of doom but have your mounts ever been changed? From my recent experience, I got about 12 years before my rear mount gave up, I put on a new one but still had a (mild) vibration at idle and while revving..
As it turns out, ALL my other mounts were shot to sh*t... Front, transmission and side (and rear of course)..
Once one goes, if it hasnt been adressed for a while it usually tends to take the rest with it..
It is my view that the rear takes on the most forces on this car so if that has failed the smaller front and trans mount probably can't take the jamming and will fail as well
So will the front mount going out cause vibration at idle? I have the same issue. I took it to a shop recently and they said that the front mount needed to be replaced, but wasn't broken completely. My car doesn't vibrate at all when I drive it though, only at idle.
i know you dont know if your mounts are gone or not but if you find out they are
http://importnut.net/motormount.htm
shewit08
18
Jun 21, 2010 05:34 PM
car5car
Feb 28, 2009 08:07 PM
Turbo-charged
Mar 11, 2008 04:24 PM
