RI FS: 94' civic turbo MA/CT/NY
$6500 obo
It is a 1994 honda civic dx. the body has 162,000 miles. The car has been completely gone through top to bottom. Im gonna list all the stuff it has though i will probably be forgetting something. It is heavily modified. The engine bay has been completely shaved and tucked and resprayed. The holes were all welded. Clutch line has been tucked as well with bulkheads and full stainless steel line. The brake lines have all been redone tucked with no leaks. The wiring and brakes have no problems at all. Stainless steel radiator.
Just had it on the dyno and made 230whp and 180tq at 10psi. It was steet tuned on chrome. Real spoon brake and clutch fluid resivor covers. Hood is rusted i know...i have another hood to go along with car. I will tell you the color code so you can have any part painted to match. Many other spare parts come with the car such as different throttle bodies, fast idles, iacs, stock exhaust manifold, stock injectors, stock fuel pump..everything you need to unturbo it should you ever want to.
Motor:
-94 LS motor with only 75k on it. it was pulled form an auto integra that was hit in the rear. I got it when the motor had only 80k.
-the motor has been completely gone through by SPAR automotive. It was cleaned, head resurfaced, block decked. everything was bench tested for cracks and any other problems.
-ARP head studs
-AEM fuel pressure regulator with b&m gauge
-OEM headgasket
-new OEM water pump
-new OEM timing belt
-BDL cam seal
-motor has been primed and repainted perfectly
-innovative race black insert motor mounts polished
-all new gaskets
-no leaks at all
Transmission:
-has no grinds or problems at all
-brand new slave cylinder
-Competion stage 4 clutch
-Fidanza 7lb flywheel
-ARP pressure plate bolts
Turbo:
-t3/t4 .50 trim
-3" inch down pipe with a full straight 2.5" exhaust
-2" aluminum piping to 2.5" piping to throttle body
-dsm balck top 450cc with 10watt/10om resistors wired in to accompany
-Tial 38mm wastegate
-hallman boost controller
-Greddy type RS bov
-front mount intercooler
4an- oil feed with a function 7 oil restrictor
-Brand new custom made ram horn manifold made by Daniel at D&G automotive in New York.
* kit also includes a brand new gt35r turbo with a journal bearing set up. Tbolt clamps within. Also incudes 3an- oil restrictor and 3an- line and fittings to make your new feed line. Brand new 3" 4 bolt down pipe with 50' of brand new header wrap and stainless steel zip ties. Also comes with brand new Vibrant intercooler with the newer style mounting hardware. Intercooler is rated to 500-550 hp
Body:
-Has no major issues. The quarter panels are clean with no rust. The drives door has a small dent where it took a little paint.
-Spoon mirrors
-Spoon front lip
-Spoon window banner
-EK sideskirts
-Mud flaps
-Window visors
-New windsheild
-kill switch installed in rear of car for track
Suspension:
-Tein basics
-blox adjustable upper control arms
-Brand new lower ball joints
-Brand new wheel bearings all around..front and rear
-ARP extended studs all around
-blox lower control arms in gold.
-factory gsr rear sway bar
-energy suspension red rear trailing arm bushings
-brand new ceramic brake pads front and rear
-brand new rotors front and rear
-obx rear lower tie bar
* car comes with usdm front and rear type r sway bars
Rims:
-drag dr 21's with honda center caps
-falken tires all around with ok amount of tread left
-rims are brand new with no curb rash or even scratches
-muteki lug nuts
Interior:
-NRG quick relase version 2.5 with matching nrg slim hub. NRG lock is also inculded.
-black type r replica seats with no tears or stains
-B adn C pillar bars
-interior does not have a carpet but the floor has been painted
-type r shift boot
-real mugen shift ****
-oem rear speaker covers
I have a ton of pictues of this car as well. SERIOUS people only. I will not let you test drive it for the hell of it.
If interseted call or text me at 401 573 7558
the price is negotiable though
NO TRADES
Motor:
-ARP head studs
-OEM headgasket
-new OEM water pump
-BDL cam seal
-all new gaskets
-no leaks at all
Transmission:
Turbo:
-t3/t4 .50 trim
-Greddy type RS bov
Body:
-Spoon mirrors
-Spoon front lip
-EK sideskirts
-Mud flaps
-Window visors
-New windsheild
Suspension:
-Tein basics
Rims:
-muteki lug nuts
Interior:
-type r shift boot
NO TRADES
