Brake line bleeding...
Old Jul 19, 2002 | 09:23 AM
avs's Avatar
avs
Default Brake line bleeding...
Is it necessary to bleed the brake line and get the air out of the line? I got a 94 integra and got about 119k miles on it.
Old Jul 19, 2002 | 10:15 AM
bulldog_RS20's Avatar
Default Re: Brake line bleeding... (avs)
You mean bleeding through the bleed valves on the calipers, right? (and not disconnecting the brake lines)...
If you have noticed a softer pedal or have recently done rotor/pad work, it's a good idea to bleed them. But usually a street car shouldn't need it that often...
Old Jul 19, 2002 | 10:24 AM
Todd Reid's Avatar
Default Re: Brake line bleeding... (bulldog_RS20)
street cars should have the entire brake system (and clutch, if hydraulic) flushed and rebled every two years. moisture, impurities, and rust WILL accumulate in the system and will eventually destroy the seals, master cylinders, etc if this is not done. Look at the container that you bleed into when you are done and you will be horrified at the rust particles, etc in your 119k mile old fluid....
I do this religiously to my street cars and tow vehicles and have never needed to replace any brake components other than pads. If you keep very clean fluid in your systems, you very well might never need to replace seals, master cylinders, etc.
My two race cars get flushed out/bled 3 times per year.
Todd
Old Jul 19, 2002 | 12:34 PM
avs's Avatar
avs
Default Re: Brake line bleeding... (Todd Reid)
Ok sounds good. I need something to do anyway. So any of you guys have the helm manual and dont mind scanning me the pages for this procedure. That would be great. Thanks in advance.
Old Jul 19, 2002 | 08:17 PM
Quick 200k Mile Motor's Avatar
What do you use to flush the system?
Old Jul 19, 2002 | 08:56 PM
avs's Avatar
avs
Default Re: Brake line bleeding... (Quick 200k Mile Motor)
DOT3 Brake fluid
Floren
Honda Civic (2006 - 2015)
Jun 25, 2018 07:18 PM
citegraguy44
Apr 3, 2013 12:36 PM
5thGeneration
Dec 4, 2007 08:51 PM
PINKS
Oct 18, 2007 04:25 PM
PINKS
Oct 18, 2007 06:04 AM
