O2 sensor help
I have a 2002 civic si...I got the car a few months ago with a check engine light...I check the car with and OBD2 scanner...it gave a code for secondary 02 sensor...I replaced the sensor with a Bosch sensor from autozone...I reset the code and turned the car on...the check engine light went away for about 10 minutes and came back on...it's for the sensor again...what should I do now? The car bogs sometimes and gas milage sucks...will o2 sensor cause these problems? The car is almost stock just has and HKS short ram intake...thanks
are you running a catalytic converter? i know i just replaced my sensors before inspection and run no cat with a O2 sensor defouler on my type s. i get a code that says slow response from sensor two the CEL goes on and off all the time.
Yes. The ECM is looking for a specific signal, which the spliced-in universal sensor is not providing. The heater circuits in these cars are pretty sensitive.
Pick up a Denso 234-4122. Looks like it's $44 on Amazon.
May I add also the NGK one will work great too!
crxtreme27
Sep 19, 2002 02:01 PM
