overheating problem
Old Sep 25, 2002 | 08:38 AM
takeheed's Avatar
Default overheating problem
upper rad hose hot ,lower rad hose not ??
thermostat or water pump?
Old Sep 25, 2002 | 08:53 AM
EP3_05's Avatar
Default Re: overheating problem (takeheed)
Check the thermostat first and then the water pump....I always try to eliminate things from the easiest part to change to the hardest.
Old Sep 25, 2002 | 09:01 AM
takeheed's Avatar
Default Re: overheating problem (91civic)
ok,when i take out the thermostat ,what should i look for ?if it is the prob i shouldnt be able to push it open right?
Old Sep 25, 2002 | 09:02 AM
EP3_05's Avatar
Do you have a manual? It tells you how to test it in there. I suggest getting one if you don't already have one because it is one of the best things I have ever bought for my car.
Old Sep 25, 2002 | 09:04 AM
takeheed's Avatar
problem happened on the way to my parents garage,my manual is 15 miles away at my apartment
Old Sep 25, 2002 | 09:07 AM
EP3_05's Avatar
This should help you out.
Old Sep 25, 2002 | 09:10 AM
takeheed's Avatar
holy **** your the man!!
Old Sep 25, 2002 | 09:56 AM
crx(gator)'s Avatar
do you have your fan plugged in...
Old Sep 25, 2002 | 01:00 PM
takeheed's Avatar
Default Re: overheating problem (crxgator)
yes the fan is plugged in...and working! haha,almost got me
Georgia93coupe
Mar 31, 2008 10:36 PM
christiian
18
Jul 16, 2006 12:03 AM
rdeezy25
May 4, 2005 04:51 PM
Veleno
15
Mar 14, 2005 09:03 PM
92civic227
Mar 13, 2005 04:19 PM
