idle problem!
having an idle issue.on start up my car idles at 3,000 and as it warms up it bounces between 1,000 and 2,500 constantly. already cleaned my IACV and FITV and they are both in good working condition. any suggestions??
Any CEL codes?
After the engine has fully warmed up and has the high fluctuating idle problem, use your finger to cover the port inside the throttle body leading to the FITV. Do you feel any suction? Does this prevent the idle problem?
If not, do the same test on the port leading to the IACV.
Had the same issue, turns out it was the white plate that holds the spring down on the FITV, came loose so I screwed it back in and it was golden.
haha jk man dont mean to thread bash alot of hondas have that problem. i had that problem to id spray some blaster on it. if that dont work a buddy of mines was jumping from 2000 to 3000 and i checked for vaccum leaks put a hose on it. and moved the dizzy back a little bit. fixed it real quick
There can only be a certain amount of things it is, but when an idle is that high usually is a vacuum leak due to pulling in a lot of extra air rather than a small vacuum leak (dont quote me). You can use unlit propane too, this always works better and as you know gas is much more speratic and should help find the leak. The extra octane from the propane will raise the idle, or sometimes bog.
If you unplug the IACV what does it do?
SilverSellout
12
Feb 27, 2004 12:48 PM
