Vtec STILL isnt working
Old Feb 7, 2011 | 05:26 PM
MyDeeCee2's Avatar
Icon7 Vtec STILL isnt working
ok so i posted a thread like least week about my vtec. like i said i have 98 type r swap from hmo in a 97 ls. my thermostat was done and it always took a long *** time for the needle to rise up. even though the car was already warmed up. and when it finally did get a little past C . my vtec worked again.. so now i changed out my whole thermostat. the gauge works fine now.. but my VTec doesnt work at all. any ideas? it really annoying. new solenoid maybe?
Old Feb 7, 2011 | 05:40 PM
night's Avatar
Default Re: Vtec STILL isnt working
gauge doesn't mean anything to the computer.
either put a scanner on it or find the spec chart and stick an ohm meter on the sensor.
Old Feb 7, 2011 | 09:02 PM
MyDeeCee2's Avatar
bump
Old Feb 8, 2011 | 11:52 PM
Fo-Do Fanatic's Avatar
Is your ground on your thermostat housing tight and good? For good measures clean the contact on the ground wire AND on the thermostat housing itself to ensure that it's getting a good ground. Also, is your coolant level good? VTEC will NOT engage without having enough oil pressure nor enought coolant.
Old Feb 10, 2011 | 12:15 AM
maximusej6's Avatar
x2
Old Feb 10, 2011 | 01:25 AM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
Old Feb 10, 2011 | 07:26 AM
night's Avatar
if the tstat ground wasn't making good connection vtec would be the least of his problems
Old Feb 10, 2011 | 11:24 PM
This is true. I know that's the ground for the ECU but something that you wouldn't think would cause the problem, can. It's sort of a precautionary thing you know? LOL
MyDeeCee2
Feb 3, 2011 06:35 PM
supersonic782g
Jun 25, 2009 01:33 PM
everythingwentblack
16
Mar 3, 2008 08:25 PM
SPEEDQUEST INC.
13
Mar 16, 2005 08:52 AM
b16aeg
Aug 2, 2002 04:41 AM
