heater question
Old Feb 6, 2011 | 07:05 AM
tallguy21's Avatar
Default heater question
idk if you all saw my other post, but I recently bought this car, and it does not have heat haha....ehhh
anyways, he told me what was missing was the "valve on the firewall"
is that something that can be easily obtained and taken care of?
Does that description make sense? Like I said before I'm not the most mechanically inclined person especially with a Honda, so this is all a learning process for me.
I appreciate any help that can be thrown my way.
Old Feb 6, 2011 | 07:14 AM
Former User's Avatar
Default Re: heater question
Two coolant hoses run from the engine to nipples on the firewall. The two hoses supply hot coolant from the engine to the heater core behind the dash. Are these two hoses connected? If so, one of the two hoses (inlet) connects to a valve. This valve is controlled by a cable from the heater control panel. If the cable is disconnected, then you can manually turn the valve on so that hot coolant can circulate through the heater core.
Old Feb 6, 2011 | 07:20 AM
tallguy21's Avatar
i'm going to shoot you a pm later on, i'm going to go check that out.
thanks for your response
Old Feb 6, 2011 | 08:46 AM
grumblemarc's Avatar
The Grumpiest
Check the last line in his signature.
Please do not PM me tech questions. Create a thread.
Old Feb 6, 2011 | 10:27 AM
tallguy21's Avatar
^lol^ my fault...good call..when I get to checking heater out i'll post it up here then...sry about that
andyz
Apr 6, 2022 08:14 PM
LatnKng
Nov 27, 2011 08:15 AM
mrspeedy69
13
Nov 19, 2009 06:30 AM
crex23
Nov 3, 2009 06:08 AM
Fatty_1775
Jul 16, 2003 06:59 AM
