Is my thermostat stuck?
Old Feb 5, 2011 | 10:35 AM
rich7777's Avatar
Icon2 Is my thermostat stuck?
Hey guys,
Does this sound like my thermostats stuck shut ?
I was tuning earlier and after a while i noticed my coolant temperature starting to get quite high. I pulled over in a layby thinking **** has my head lifted or head gasket failed (thinking the worst). I then thought to myself "what if it just the thermostat". I then turned the heaters on and the coolant temperature started to drop fast so i decided to start driving home with my heaters on.
Whilst i was driving back i switched the heaters off and the coolant temperature started to climb again so i turned them back on and it started droping again.
When i got back i done a compression test and all cylinders were spot on. I got close to 140psi across all of them which is what i normally get.
Thank you for your time
Old Feb 5, 2011 | 11:03 AM
98civdx's Avatar
Master Detailer
Default Re: Thermostat
My was doing the same thing you said.
When I turned the heat on, the temp dropped like a rock.
I switched the thermostat and re filled and bleed the cooling system, and it is just fine now.
Old Feb 5, 2011 | 12:23 PM
D Griff's Avatar
Seems like it could definitely be a thermostat.
Old Feb 5, 2011 | 01:02 PM
95ProjectEJ1's Avatar
Have you made sure the coolant fan is engaging at temp? You can always start the car when its COOL and pop the radiator cap off. Wait for it to get to temp and the water should start to circulate once the thermostat opens.
Old Feb 5, 2011 | 01:06 PM
rich7777's Avatar
Yeh the cooling fan definatly comes on. I'm 100% on that...
Old Feb 6, 2011 | 08:43 AM
rich7777's Avatar
Default Re: Is my thermostat stuck?
I've just taken the car out for a spin and i doesn't over heat now ? ? I guess its probably un stuck its self... I'me going to change it anyway. I've ordered 2 gates racing low temp thermostats.
Old Feb 6, 2011 | 11:04 AM
98civdx's Avatar
Master Detailer
Be sure to get a new gasket.
Hoopdie91
Apr 3, 2016 06:15 AM
mikeryan161
Dec 16, 2012 03:36 PM
bandit080000
Honda Civic (2001 - 2005)
Jul 1, 2010 11:09 AM
Fighterinsnatch
11
May 21, 2007 02:43 PM
SOHC_MShue
Apr 16, 2005 02:42 PM
