Cannot rotate dizzy far enough to time car
I searched and couldn't find anything to answer my problem. The dizzy is cranked all the way and the mark on the pulley is close to the indicator but not quite there. My cam gears do line up when TDC. What am I missing here? I have hondata and I go to online>set timing>16*BTDC. Do I still need to jump the service connector? Will an exhaust leak also have an affect?
Turbo'd LS/VTEC
Turbo'd LS/VTEC
mines turned all the way advanced and my timing is right on the money but I cant advance it if I wanted to.I hope someone has an answer for you so I can fix mine as well.
I HAVE THIS SAME EXACT PROBLEM ON MY DA..MY CAR STARTS FINE AND EVERYTHING AND SOUNDS LIKE IT IDLES FINE BUT WHEN I START TO TAKE OFF BETWEEN 1000RPM AND 3500RPM THERES LACK OF POWER LIKE A MISFIRE OR PREIGNITION.. AND IM WASTING ALOT OF GAS..RUNNING RICH MAYBE????
put hondata back to original configuration and jump the connector.
see if that works.
at idle yourecu constantly adjusts timing to get the engine idle smooth.
test connector sets timing constant to default pposition so you can check it and adjust the initial position.
see if that works.
The cam gears line up guys. Im not dremeling the holes. They're slotted that big for a reason. I cant put hondata back to original, how would my LS/VTEC TURBO start. I'll tell ya- Really ****ing bad or not at all. Mark on the crank pulley-red.
On top Dead center MY cam gears line "up" up and line the 2 notches together in the center.
I know that. When the car is running, I'm trying to get the indicator to point to the red mark. When the car is off, I can get the engine to TDC, and the cam gears line up
I am running stock Pr3 camgears. The tune is for this setup. The only thing i changed to have the timing out of sync was the distributor. Before the timing was fine
are you using the correct distributor by chance? if you say eveything in the engine lines up then it could be the wrong distro.
It won't be the software that is causing the prob. what kind of timing light are you using?
if it's a dial back timing light then check what timing your getting when distro is set in the middle. If everything in the engine is lined up, including distro, then it should be in the middle.
My timing light does not have individual settings. Also, I just diagnosed another car problem by guessing, and checking. I'd rather not do it here if i can avoid it, seeing as how that costs so much money.
If you had your block decked and head decked or both, you'll need adustable cam gears and degree your motor properly using a cam degree wheel and dial indicators to get it bang on. You can do this with the motor still in the car, but you'll need someone to do it for you that knows how to do it.
StevieR
16
Feb 5, 2011 05:50 AM
the.hamburglar
Mar 10, 2006 06:23 PM
