Cannot rotate dizzy far enough to time car
Old 02-02-2011, 09:19 PM
StevieR's Avatar
Default Cannot rotate dizzy far enough to time car
I searched and couldn't find anything to answer my problem. The dizzy is cranked all the way and the mark on the pulley is close to the indicator but not quite there. My cam gears do line up when TDC. What am I missing here? I have hondata and I go to online>set timing>16*BTDC. Do I still need to jump the service connector? Will an exhaust leak also have an affect?
Turbo'd LS/VTEC
Old 02-02-2011, 09:33 PM
Winlight's Avatar
Default Re: Cannot rotate dizzy far enough to time car
mines turned all the way advanced and my timing is right on the money but I cant advance it if I wanted to.I hope someone has an answer for you so I can fix mine as well.
Old 02-03-2011, 04:13 PM
usdmsol's Avatar
if you are really close you could prob. just dremel out the holes a little bit, prob. not the right way but just a suggestion.
Old 02-03-2011, 04:14 PM
weavertime1's Avatar
It must be off a tooth to do this...
Old 02-03-2011, 04:43 PM
Winlight's Avatar
thats what I think as well,Im going to replace my timing belt and put it on right.
Old 02-03-2011, 04:50 PM
cream1316's Avatar
I HAVE THIS SAME EXACT PROBLEM ON MY DA..MY CAR STARTS FINE AND EVERYTHING AND SOUNDS LIKE IT IDLES FINE BUT WHEN I START TO TAKE OFF BETWEEN 1000RPM AND 3500RPM THERES LACK OF POWER LIKE A MISFIRE OR PREIGNITION.. AND IM WASTING ALOT OF GAS..RUNNING RICH MAYBE????
Old 02-03-2011, 04:55 PM
cream1316's Avatar
I WAS THINKING THE SAME BUT I DONT THINK THIS IS THE RIGHT THING TO DO PLUS IM USING ALOT OF GAS
Old 02-03-2011, 05:53 PM
tales sol's Avatar
are you sure your using the correct mark on the crank??
adjustable cam gears by any chance??
Old 02-03-2011, 06:03 PM
raverx3m's Avatar
put hondata back to original configuration and jump the connector.
see if that works.
at idle yourecu constantly adjusts timing to get the engine idle smooth.
test connector sets timing constant to default pposition so you can check it and adjust the initial position.
Old 02-03-2011, 08:34 PM
StevieR's Avatar
The cam gears line up guys. Im not dremeling the holes. They're slotted that big for a reason. I cant put hondata back to original, how would my LS/VTEC TURBO start. I'll tell ya- Really ****ing bad or not at all. Mark on the crank pulley-red.
On top Dead center MY cam gears line "up" up and line the 2 notches together in the center.
Old 02-03-2011, 08:59 PM
HAMOTORSPORTS's Avatar
The white mark on the crank pulley is TDC, not the red mark. The red mark is indicator of 16* BTDC
Old 02-03-2011, 10:26 PM
StevieR's Avatar
I know that. When the car is running, I'm trying to get the indicator to point to the red mark. When the car is off, I can get the engine to TDC, and the cam gears line up
Old 02-04-2011, 02:42 AM
tales sol's Avatar
your head and block arent skimmed too much by any chance?
Old 02-04-2011, 06:38 AM
habib's Avatar
Are you running of a tune that is for your setup or a base map tune?
Old 02-04-2011, 08:41 AM
MR.johnson's Avatar
if your head and/or block were decked you need to degree the motor and set aftermarket cam gears to stock degree.
Old 02-04-2011, 11:14 PM
StevieR's Avatar
I am running stock Pr3 camgears. The tune is for this setup. The only thing i changed to have the timing out of sync was the distributor. Before the timing was fine
Old 02-05-2011, 05:50 AM
Former User's Avatar
Jump the service connector and adjust the ignition timing of the fully warm engine only if it is idling to spec.
Thread also copied to the Engine Management forum.
StevieR
Engine Management and Tuning
21
03-02-2011 07:39 PM
d16trex
07-17-2008 11:04 AM
the.hamburglar
03-10-2006 06:23 PM
Nextelbuddy
03-25-2004 08:32 AM
carcala
01-18-2003 04:06 PM
Quick Reply: Cannot rotate dizzy far enough to time car
