CEL blinking while driving (b16a2 on 99 ek )
Old Feb 4, 2011 | 06:45 AM
oneEg1Tc's Avatar
Default CEL blinking while driving (b16a2 on 99 ek )
so i had this problem a few weeks ago, i was driving to work when out of no where my car started to "choke" "studder" on take off , then the cel while come out and started to blink like crazy. When we tried to get the codes outs no codes would come out ,so we thought was a bad ecu , we changed ecu and problem was gone, passed BAR and they scanned it, no codes came out. Yesterday while driving back home CEL came out bliking again so i assumed it was a ecu, changed ecu and started to blink again while driving and then it would go away but car will still choke. I tried gettin the codes out and i get a code #71 random misfire cylinder 1 .... has anybody had this problem ? what could it be ? wires are new, sparkplugs are fine , there's spark and fuel getting there ... any imput is appreciated thanks
Old Feb 4, 2011 | 06:48 AM
Former User's Avatar
Default Re: CEL blinking while driving (b16a2 on 99 ek )
A blinking CEL indicates misfiring severe enough to damage the cat. Have you inspected the cap, rotor, and distributor internals?
Old Feb 4, 2011 | 06:55 AM
oneEg1Tc's Avatar
first time it happened we also changed the complete dizzy with internals and everything and thats less than a month
Old Feb 4, 2011 | 07:11 AM
Did you install an OEM distributor? Some new/rebuilt aftermarket distributors are bad out of the box.
Also, when was the fuel filter last replaced? Are the fuel injectors clogged? You could also try unplugging the primary O2 sensor to see whether this eliminates the problem.
Old Feb 4, 2011 | 07:16 AM
oneEg1Tc's Avatar
it was replaced with a friends working dizzy , since his car was going to paint i got his dizzy and his was working perfectly , fuel filter was replaced when swap was done a month and half ago, and regarding the injectors i used a lucas treatment the first week of the swap thinking "to be on the safe side". On the O2 sensor just unplug it ?
Old Feb 4, 2011 | 07:18 AM
Yes, the primary sensor. Have you inspected the spark plugs?
Old Feb 4, 2011 | 07:35 AM
oneEg1Tc's Avatar
yes that was one of the first things i checked gaps are ok they still give the blue spark , they don't look burned or nothing
Old Feb 4, 2011 | 07:39 AM
Spark should be bright white with only a faint hint of blue.
Old Feb 4, 2011 | 07:46 AM
oneEg1Tc's Avatar
yeah thats what i ment to say,
slowem1si
Jan 11, 2009 10:24 AM
CornFlake340
Jul 24, 2005 04:09 PM
liquidxEG
Feb 22, 2005 03:46 PM
boost junky 71
Jun 11, 2004 03:09 AM
Pfieff
Aug 31, 2003 05:23 PM
