act flywheel? bolts 9 or 6
Old Feb 3, 2011 | 02:13 PM
ser13's Avatar
Default act flywheel? bolts 9 or 6
i just got my act flywheel in..i seen that it has 9 holes to hold the pressure plate where my old flywheel had 6 do i need to use all 9? i will be using a exedy stage 1 clutch?
Old Feb 3, 2011 | 02:26 PM
Gunmetal_B20_Hatch's Avatar
Default Re: act flywheel? bolts 9 or 6
3 of the holes are for dowel pins. They are highly recomended.
Old Feb 3, 2011 | 02:27 PM
habib's Avatar
^ this
Old Feb 3, 2011 | 02:46 PM
weavertime1's Avatar
...3 are for dowel pins, and there is usually only one way that the clutch will go on. Good luck!
Old Feb 4, 2011 | 05:32 AM
ser13's Avatar
No the actual flywheel has 3 extra bolt holes makn a total of 9...where my stock flywheel only had six plus the three dowels.
Old Feb 4, 2011 | 08:46 AM
MR.johnson's Avatar
you can run the bolts the same way as the stock one was. i have done it both ways.
kpop
May 21, 2006 04:54 PM
remaxxxk
Mar 1, 2006 09:11 PM
Goldfingiz
May 17, 2003 10:30 PM
275Performance
Apr 30, 2003 05:03 PM
01ITR#700
Oct 23, 2002 06:35 AM
