flywheel and clutch question!
Old 05-20-2006, 07:24 AM
kpop's Avatar
Default flywheel and clutch question!
i just got a fidanza flywheel and a 6 puck clutch.
i tryed installing it and the bolts from my stock clutch doesn't go into the flywheel to hold the clutch. the thred is different. could it be a vtec flywheel because my block is non vtec.
Old 05-20-2006, 07:29 AM
garados's Avatar
Default Re: flywheel and clutch question! (kpop)
the flywheel should have come with new bolts. As far as vtec vs nonvtec thread pitches, I don't know.
Old 05-20-2006, 08:11 AM
kpop's Avatar
Default Re: flywheel and clutch question! (garados)
i didn't get new flywheel bolts
i had to use my stock ones because the arp didn't bolts didn't go in all the way theres still a little gap.
Old 05-20-2006, 10:08 AM
garados's Avatar
are the holes in the flywheel a certain depth? or are they all the way through? If they are all the way through and torqued properly, perhaps you put the disc in backwards, misaligned the pins, or something strange like that? Just a thought ...
Old 05-20-2006, 12:35 PM
blkb18's Avatar
i put in a fidanza flywheel in my 96 gsr and had no problem with the factory bolts, I dunno?
Old 05-20-2006, 07:02 PM
Sam92Teg's Avatar
Default Re: flywheel and clutch question! (blkb18)
7.5 lb. Fidanza with stock bolts on a B18A here, I freakin love this flywheel.
Old 05-20-2006, 07:39 PM
teddy_dc2's Avatar
had a clutchmaster stg 3 with c.m 8lb f.w, no bolts came with it and stock ones fit it. clean up the dirt for less future problems. what kinda 6 puck is it? should fit if it's for your car
Old 05-21-2006, 07:23 AM
kpop's Avatar
Default Re: flywheel and clutch question! (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">7.5 lb. Fidanza with stock bolts on a B18A here, I freakin love this flywheel. </TD></TR></TABLE>
everything fits but the stock bolts for the clutch won't go in the flywheel. its the same size maybe i can show u guys some pics tomarrow when i gave time.
Old 05-21-2006, 07:24 AM
kpop's Avatar
buy the way where did u order the flywheel at?
Old 05-21-2006, 07:28 AM
kpop's Avatar
any more suggestions?
Old 05-21-2006, 07:38 AM
kpop's Avatar
is there a difference between non-vtec and vtec fidanza flywheel or are they all the same.
Old 05-21-2006, 07:57 AM
mr.beeks's Avatar
Default Re: (teddy_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teddy_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">had a clutchmaster stg 3 with c.m 8lb f.w, no bolts came with it and stock ones fit it. clean up the dirt for less future problems. what kinda 6 puck is it? should fit if it's for your car</TD></TR></TABLE>
hello
for a minute there I thought it was me posting cause of the avatar....
it happens when you buy aftermarket sometimes the thread needs to be redone....
the flywheel is suppossed to be just a bolt on no mods needed.
Old 05-21-2006, 04:54 PM
kpop's Avatar
Default Re: (mr.beeks)
i think it needs to be redone too.
im bringing it to a shop tomarrow.
ser13
02-04-2011 08:46 AM
hotrodlincoln
09-26-2006 04:10 PM
preluda92
08-30-2003 02:29 AM
275Performance
04-30-2003 05:03 PM
01ITR#700
10-23-2002 06:35 AM
Quick Reply: flywheel and clutch question!
