Suspension & Brakes Theory, alignment, spring rates....
Strut replacement??
Old Feb 3, 2011 | 12:32 PM
lxdriver's Avatar
Icon2 Strut replacement??
So the mechanic said my front two struts are bad, supposedly "they are leaking" and that I need to replace them. They (firestone) want to charge me like $300 to buy and replace the front 2 struts soooooooo FORGET THEM FOR THAT!!!! cuz I can do that myself, what I want to know is how can I make sure that my struts are leaking or if they're still good for sometime. And if they are bad, what harm can be done to the car if I leave them "bad" like that?
Old Feb 3, 2011 | 06:09 PM
egsleepercivic's Avatar
Default Re: Strut replacement??
if they are leaking you will see oil or fluid on your shocks, jack it up and take a look
Old Feb 4, 2011 | 12:23 PM
fowrdowr's Avatar
You'll need a compressor. Don't do it without one. It'll take a few good hours also, if you are doing it your first time.
Old Feb 4, 2011 | 05:42 PM
lxdriver's Avatar
A compressor? U mean a coil spring compressor?
Old Feb 6, 2011 | 01:41 PM
jmarquardt0221's Avatar
no he means an air compressor. You can do them with hand tools but doing the job with air tools are faster. You will a need coil compressor tho, in order to take the springs off correctly. I would steer away from just losing up the the strut nut and letting the spring go.
Morasso
Dec 19, 2007 07:20 AM
Toolman
Suspension & Brakes
May 2, 2005 06:30 AM
96hb
23
Apr 19, 2004 02:10 PM
ryaneg6
Nov 17, 2002 12:07 PM
CRX-RX
Jan 23, 2002 10:49 AM
