'92 vx b18c1: knock sensor(code 23)
Old Feb 2, 2011 | 02:51 PM
rhymeshark916's Avatar
Default '92 vx b18c1: knock sensor(code 23)
I'm using a gsr engine harness and I re-pin the blu/ylw wire from the shock tower by doing this https://honda-tech.com/forums/hybrid-engine-swaps-18/complete-obd1-b18c1-into-civic-vx-wiring-instructions-644434/.
Enginge specs:
95 obd1 longblock
stock t/b & i/m
ctr cams
rs machine type r pistons
dc 4-1 header
stock obd1 p72 ecu
brand new omni knock sensor
b16 tranny
Do I need to get a new sensor from autozone? The one from Omni might be bad even though it's brand new. Also, I wired from ks to ecu directly and it still pulls the code.
Any help, ideas or suggestions is appreciated, TIA.
Old Feb 3, 2011 | 03:46 AM
Default Re: '92 vx b18c1: knock sensor(code 23)
BUMP
Old Feb 3, 2011 | 06:12 AM
ifIexplode's Avatar
Did you ground the knock sensor?
Old Feb 4, 2011 | 02:49 AM
what you mean ground? I did what did on the link I provided. I'm going to post on another forum since I'm not getting answers.
Old Feb 5, 2011 | 03:40 AM
wow.....
Old Feb 6, 2011 | 08:11 AM
aaron_drifter's Avatar
the only thing i can think of is either a defective knock sensor. i would purchase another from advanced or autozone and torque it to the proper honda torque spec. i have trashed a new knock sensor by over tightening it so try that first.
Old Feb 7, 2011 | 08:51 AM
bump//////
Old Feb 7, 2011 | 11:24 AM
Old Feb 7, 2011 | 11:48 AM
NVturbo's Avatar
O.G. triple O.G.
You don't ground the knock sensor. If you are using the orginal engine harness, it should work fine. You MUST tap into the red/blue wire at the driver's side plug and run a wire into the D3 slot (ECU).
Was the original KS damaged or something?
Old Feb 7, 2011 | 01:08 PM
brand new from omni from iapdirect.com
mxracer420
Apr 27, 2009 08:44 PM
Black_Rex
Jan 23, 2006 03:27 PM
tc_gts
11
May 4, 2005 05:26 AM
MlnknprkrM
Nov 11, 2004 06:42 PM
no2psi
May 11, 2003 10:35 AM
