Squeeking/Creeking noise in the drivers front
Old Jan 31, 2011 | 01:09 PM
elnoyl's Avatar
Default Squeeking/Creeking noise in the drivers front
At lower speeds i can hear it making a squeeking/creeking noise in the drivers front. If i turn the wheel back and forth it also makes that noise. I got out of my car and pushed down directly on the drivers fender a few times and it makes the noise. It obviously sounds like something in my suspension so what should i check out? It's a 2000 ex coupe with 148k on it with stock suspension.
Old Jan 31, 2011 | 03:08 PM
Crex167's Avatar
Default Re: Squeeking/Creeking noise in the drivers front
probably too dry. i'm not a great tech or what not. but in my friends accord, he has pretty old shocks and springs, when they depress they squeek but after its wet like a car wash or rainy day it sounds ok. probably old or not lubed, my guess
Old Jan 31, 2011 | 04:31 PM
elnoyl's Avatar
i am in MN and wash my car like every 2 to 3 days in the winter and it's still making that noise.
Old Jan 31, 2011 | 04:38 PM
canadaek's Avatar
check you balljoints sounds like one is siezing up
Old Jan 31, 2011 | 05:10 PM
AutoXer's Avatar
First thing I'd check is the bushings. They're probably all shot. Then shock mounts, then the suspension components themselves. How bad is it? It could be a lot of work to take care of...
Old Jan 31, 2011 | 05:57 PM
elnoyl's Avatar
the car has had all 4 wheel bearings and all 4 struts and the front lower ball joints done. I hear the noise constantly at lower speeds and when i turn the wheel.
Old Jan 31, 2011 | 06:03 PM
f22vx's Avatar
get a can of spray lube and soak it all down in there. :D 148k is a long time to have the same suspension. ive heard your suppossed to replace struts every year
Old Jan 31, 2011 | 06:04 PM
grumblemarc's Avatar
The Grumpiest
Where did you hear that nonsense?
Old Jan 31, 2011 | 06:10 PM
f22vx's Avatar
autozone, but i live on a mountain range so shocks go out pretty quick
Old Jan 31, 2011 | 06:12 PM
JDMxTai's Avatar
I have the same problem sort of and I have tokico blue shocks the winter drive made them shot. But it's either dry ball joints or your struts are shot. Better of getting new strut. Theres a bushings or bearing or cushion on the strut that makes that noise
Old Feb 18, 2011 | 07:01 PM
1991crx16's Avatar
Hey just wondering if you ever figured out what the problem was? Same exact thing happens with my car. First thought it might be the shocks but they have been replaced and still does it. Has not made any noise all winter, now that its starting to warm up I hear it again. I have been told the ball joints but not sure.
Old Feb 19, 2011 | 05:45 PM
elnoyl's Avatar
It was a lower ball joint. All the grease leaked out and it was really stiff to move the joint around. I replaced both sides myself.
slateEKsi
15
Aug 10, 2021 04:43 PM
Brada34
Honda Civic (2001 - 2005)
Feb 21, 2014 03:47 AM
wh1teredneck
Jul 14, 2010 10:28 AM
skip.two
Suspension & Brakes
Jun 14, 2009 07:38 AM
USjdm
Honda Civic (2006 - 2015)
Nov 10, 2008 11:50 AM
