Ignition coil question
Old Jan 30, 2011 | 11:29 AM
Lasky's Avatar
Default Ignition coil question
Ok so I drove my car home the other day and it was fine and then I go to start it later and nothing, it just turns over but has no spark.. I took the plugs out and they had gas on them.
So I check my ignition coil and the primary reading is at .8ohms in spec however the secondary is at 11.22Kohms which is out of spec.
I have a jdm b16 and dont know if the readings are supposed to be the exact same as whats in the manual since its the D16 engine in the manual.
Anyone have any input on that?
Also I performed the test on the car while it was outside and the temperature is probably around 30 today, dont know if I should take it off and test it inside?
Old Jan 30, 2011 | 12:24 PM
Hondatherdm's Avatar
Default Re: Ignition coil question
your secondary has a break, new dizzy
Old Jan 30, 2011 | 12:34 PM
egsleepercivic's Avatar
don't replace the whole dizzy just the coil
Old Jan 30, 2011 | 01:50 PM
BryanM.'s Avatar
Resident Gearhead
Yes the Ohm readings will be the same for all D and B series engines '92-'01 with Tec distributors. The coils themselves are all the same.
You should bring it inside and get it up to about 70ºF and retest it but I bet it still won't hit spec.
You can get just the coil.
Old Jan 30, 2011 | 01:53 PM
Jimmy's Avatar
Global Moderator
Good info guys.
Old Jan 30, 2011 | 05:53 PM
Lasky's Avatar
alright im going to bring it in and test it at room temperature tomorrow morning.
I noticed that my rotor looks like its a burnt clutch, the outside that touches the contact points looks worn down and all the contact points had carbon on them plus there was a little carbon on the inside of the cap.
Anyone think the cap and rotor may be the problem?
Old Jan 31, 2011 | 04:50 AM
BryanM.'s Avatar
Resident Gearhead
Absolutely. Replace both and test the coil while your in there.
Easy stuff.
The cap terminals can get really nasty after years of use.
trunkmonkey108
Honda CR-V & Element
May 29, 2013 01:38 PM
gutted
Feb 22, 2006 08:47 AM
undagroundrican
Feb 20, 2006 06:25 PM
toooslow
Aug 20, 2003 09:12 PM
