To much play in timing belt on b18b?
Old Jan 29, 2011 | 05:46 PM
96Formula6spd's Avatar
Default To much play in timing belt on b18b?
Hey is there to much play in my new timing belt. 2nd time doing one and its the only thing I suck at. Failed at the first and and damaged a 4g63. Anyways I think this has to much play. I could be wrong. Let me know what you think.
http://www.youtube.com/watch?v=UaS3NV5DTc8
Old Jan 29, 2011 | 06:01 PM
theft24's Avatar
Default Re: To much play in timing belt on b18b?
tighten it
Old Jan 29, 2011 | 06:03 PM
how exactly would you do that. Did what the haynes manual said and no luck
Old Jan 29, 2011 | 06:05 PM
theft24's Avatar
best way that ive found is take a decent size common screw driver and pry up on the tensioner pulley and hold it and tighten the bolt back, if the belt whines while its runing its too tight
Old Jan 31, 2011 | 05:32 AM
Jenkinsal2's Avatar
If you cannot figure out how to use the tensioner to tighten the belt, I would recommend you have someone else work on your car.
Old Jan 31, 2011 | 05:44 AM
b18c8's Avatar
whats happening if your doin the timing yourself its jumping back a tooth or 2 (INTAKE cam)when u tighten it causing it to be loose get sumone to put a 12mm on the intake n go it again n keep it tight while the belt it on it until u finish doin the tensioner!! the intake cam wont stay exactly straight up like the ex cam check it out
Old Jan 31, 2011 | 05:47 AM
b18c8's Avatar
put the ex cam str8 up n the intake a tooth back n turn the intake str8 up with the 12mm to make that top tight then go to the tensioner and your good
Old Jan 31, 2011 | 05:50 AM
Yeah were working on it. Got a friend coming over to help tomorrow.
Old Jan 31, 2011 | 05:58 AM
b18c8's Avatar
kool he should knock it out
Old Jan 31, 2011 | 06:54 AM
theft24's Avatar
who is this to?
Old Jan 31, 2011 | 08:02 AM
Jenkinsal2's Avatar
The person having issues with his timing belt? Its not super complicated...
Old Jan 31, 2011 | 08:27 AM
Yeah I am the one having trouble. I have rebuilt engines before. Just never done timing belts.
Old Jan 31, 2011 | 12:48 PM
v8killaz's Avatar
i grab a long screwdriver sometimes i pry on the tensioner but usually i just pry the waterpump gear up and it keeps the belt nice and tight.
dleccord
Apr 13, 2020 08:03 AM
jvonb
Dec 18, 2005 07:47 AM
weraider30
Jul 24, 2004 10:36 AM
sivik2nr
Jun 3, 2003 07:43 AM
