94 DX crank pulley
Jus break the nut loose and give it a yank BUT WATCH FOR THE KEYWAY YOU DON'T WANT TO LOSE THIS
Sometimes breaking the bolt loose can be a real challenge, I had to go to my buddy's diesel repair shop and have him use the 3/4in gun to break the biatch loose but then the pulley came right off
Hope this helps, lemme kno if yu have questions... I've dealt with these guys a lot, I always have issues with them
Soak the bolt overnight in PB Blaster or equivalent before you wrench it.
You'll generally need this tool unless you have a powerful impact wrench.
Thanks guys, I'll let ya know how it goes.
File in the flywheel to jam up the engine and then a 4-ft cheater.
Just tap the pulley and pull it off. That's why the bolt is on there so tight...there is nothing else holding that pulley on.
jonnythan
14
Nov 27, 2008 09:53 AM
hatchdrvr
Feb 13, 2003 04:07 PM
