Civic 1999 cluster gauges are not working, help
Old Jan 27, 2011 | 06:34 PM
plamen's Avatar
Default Civic 1999 cluster gauges are not working, help
Trying to do my own wiring on my 1999 Honda Civic EX, and the dashboard gauges and lights are no longer working. I check all the fuses they are Ok.
Old Jan 27, 2011 | 06:46 PM
TwoFaced's Avatar
Default Re: My dash boeard no working Civic 1999, help.
Lol...were you drunk when you posted this thread title?
Is it just the gauge lights not working or are the climate control lights gone too?
Old Jan 27, 2011 | 07:06 PM
plamen's Avatar
the climate lights working and the back lights on the dash and the red light for battery. the guages is not working.
Old Jan 28, 2011 | 03:15 AM
TwoFaced's Avatar
Take out the cluster and check all the plugs in the back.
Old Jan 28, 2011 | 03:33 AM
grumblemarc's Avatar
The Grumpiest
Was it working BEFORE you did your rewiring?
Old Jan 28, 2011 | 05:40 AM
plamen's Avatar
everything was working perfect before i mess up with my wiring. i removed everything, i took of the dash, check visually looking god nothing burned. i check all so the both blue, yellow and green connectors in the car there is only one of the pins has power on the blue connector. I don`t know what to do.
Old Jan 28, 2011 | 10:48 PM
plamen's Avatar
i planing to buy a computer and change it and dashboard, anybody ware is the location of the computer?
Old Jan 29, 2011 | 06:51 AM
Former User's Avatar
Don't do this^. Check whether dash fuse 25 is blown.
Old Jan 29, 2011 | 10:13 AM
plamen's Avatar
I checked before couple times its ok.
Old Jan 29, 2011 | 10:23 AM
Are you sure you checked fuse 25? Did you check for voltage on both top test tabs using a multimeter with the key in ON(II)? Click the fuses link in my signature.
Old Jan 29, 2011 | 01:18 PM
johnson8861's Avatar
Fuses are cheap, replace it any way. Fuses sometimes don't look blown when in fact they actually are.
Old Jan 29, 2011 | 08:35 PM
plamen's Avatar
Default Re: Civic 1999 cluster gauges are not working, help
you are very very right. the fuc**ng fuse #25 was the problem. I check that fuse 3-4 times with test-lamp and the two ends the light comes, but when change the fuse with the new one everything start working. thank you very very much
silvergo
May 20, 2005 12:05 PM
slammedef06
Audio / Security / Video
Jan 31, 2005 09:01 AM
slammedef06
Jan 30, 2005 07:44 PM
Mike36
Feb 26, 2003 08:14 AM
