Dash Lights Stopped Working. Please Help
Old Jan 30, 2005 | 04:54 PM
slammedef06's Avatar
Default Dash Lights Stopped Working. Please Help
i installed an r1 tach in my car yesterday, i had first tapped into the dimmer but the tach wasn't working properly so i spliced into the cigarette lighter and it works fine but i have no gauge cluster lights and climate control lights. fuses aren't blown, what can i check, no blown fuses and all wires are securly taped.
Old Jan 30, 2005 | 05:30 PM
EvilPinkEye's Avatar
Default Re: Dash Lights Stopped Working. Please Help (slammedef06)
underdash-relay hopefully is a the prob
Old Jan 30, 2005 | 06:12 PM
Default Re: Dash Lights Stopped Working. Please Help (EvilPinkEye)
thanks for the response, where is the underdash relay and how do i fix it?
Old Jan 31, 2005 | 09:01 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammedef06 &raquo;</TD></TR><TR><TD CLASS="quote">i installed an r1 tach in my car yesterday, i had first tapped into the dimmer but the tach wasn't working properly so i spliced into the cigarette lighter and it works fine but i have no gauge cluster lights and climate control lights. fuses aren't blown, what can i check, no blown fuses and all wires are securly taped.
</TD></TR></TABLE> Do the park lights work? if so and the fuses are good then it may be the dimmer control, pull it and check to see if you have power into it , [when parklights are turned on] and controlled power out of it when you adjust the dimmer, if no output you need to replace it 94
crazy G
Jul 9, 2013 10:03 PM
calboi
Jul 4, 2009 08:52 PM
philkehn
Nov 5, 2006 08:39 PM
slammedef06
Jan 30, 2005 07:44 PM
Mike36
Feb 26, 2003 08:14 AM
