knock sensor fitment
Old Jan 27, 2011 | 03:33 PM
ducsaim's Avatar
Default knock sensor fitment
can i use a y8 knock sensor on a zc block??
Old Jan 27, 2011 | 03:41 PM
weavertime1's Avatar
Default Re: knock sensor fitment
What ZC block in particular do you have? I wasn't aware that the older ZCs had a knock sensor. Are you building some sort of mini-me?
Old Jan 27, 2011 | 04:02 PM
ifIexplode's Avatar
Yes you can, All 92-04 Civic share the same knock sensor, Its a 2 pin connector, 12v power to ECU and a ground.
Old Jan 27, 2011 | 06:52 PM
TwoFaced's Avatar
2 pin? On the ECU side or the sensor side of the plug?
Old Jan 28, 2011 | 06:14 AM
Knock sensors are only a 1 pin connector. Again, what ZC are we talking about here?
Old Jan 28, 2011 | 07:49 AM
TwoFaced's Avatar
Yeah that's what I was thinking...I almost declared shenanigans on this 2 pin situation.
Old Jan 28, 2011 | 09:09 AM
apexi_rsx's Avatar
the heads not gonna have a spot to put the sensor ur going to have to make one most likely. drill tap and thread one or make a lil plate for it to screm into so it picks up vibration. thiers write ups how u can mock a fake one up from radio shack to pass emissions.
Old Jan 28, 2011 | 09:16 AM
TwoFaced's Avatar
Are you going to run the obd2b p2p ecu for the y8? If you run obd1 you can bypass the knock sensor.
Old Jan 30, 2011 | 04:13 PM
Also, the knock sensor usually resides in the block.
Old Jan 30, 2011 | 04:22 PM
TwoFaced's Avatar
Op gone? What application do u need a knock sensor for...if u explain the setup and reasons there might be alternatives?
Old Jan 30, 2011 | 05:59 PM
ifIexplode's Avatar
Yeah now that i think about it. Its grounded at the ECU. My bad, My cars a DX and i used a 2 pin connector with my Type R and just grounded it on the rad support. I didnt use a sheiled wire either and never had an issue. Someone may say the sensor grounds itself on the block. Never tried it that way though.
builtDseries
10
Aug 18, 2010 07:23 PM
92'si
Feb 8, 2010 06:27 PM
ridestrt
Dec 21, 2003 10:06 AM
untitled
Aug 8, 2003 08:03 PM
90crxzc
Apr 2, 2002 05:48 PM
