Need Help w/ Srp Piston Ring Gapping
Old Sep 24, 2002 | 06:06 PM
turbob18a's Avatar
Default Need Help w/ Srp Piston Ring Gapping
I have a B18b Turbo and recently purchased a set of SRP pistons w/ Standard bore adn a compression of 9:2:1 and my question is if anyone knows how much gap i should have for the Top and Second rings. I heard they must be filed to teh right gapping. Is that true??
[Modified by turbob18a, 3:10 AM 9/25/2002]
Old Sep 24, 2002 | 06:32 PM
c1hatch's Avatar
Default Re: Need Help w/ Srp Piston Ring Gapping (turbob18a)
true, i will be doing mine tomorrow, your pistons should have detailed instructions
BTW... use the search button
https://honda-tech.com/zerothread?id=245238
[Modified by c1hatch, 7:33 PM 9/24/2002]
[Modified by c1hatch, 7:35 PM 9/24/2002]
Old Sep 24, 2002 | 08:17 PM
turbob18a's Avatar
Default Re: Need Help w/ Srp Piston Ring Gapping (c1hatch)
Do you exactly what to o now>?? How much will you be gapping the top and second ring?? What tool will you be using? Please let me know how that turned out.
Old Sep 24, 2002 | 08:25 PM
Ri5e's Avatar
Do a search. There was a topic on this. There is a formula for it. You multiply the bore by some # to get ring end gap. Then you just use a feeler gauge to determine the gap. Use a file and file the end inwards.
Old Sep 24, 2002 | 09:04 PM
earl's Avatar
You got
Old Sep 24, 2002 | 10:28 PM
Flamenco-T's Avatar
Default Re: Need Help w/ Srp Piston Ring Gapping (earl)
Earl taught me how to do this....
.018 on the gap and use a piston ring filer....I had to help LsTurbo91 did his last week..and we just use a regular file and secure it to a vice, then gap the ring...make sure the ring form a square gap and also another thing earl taught me...is to smooth out the end to make sure that the ring will not catch the piston when expanding.....run the ring on the ring gap and try to pull it out slowlu and make sure they don't get caught up in the ring...
good luck...and to Earl..
stan
Old Sep 24, 2002 | 11:21 PM
turbob18a's Avatar
Thanks Earl you have been very helpful
RAWB
Apr 3, 2004 12:45 PM
boostaholic
Mar 25, 2003 09:43 PM
civicdragger818
Nov 22, 2002 07:51 AM
Thats-so-Ls
Dec 29, 2001 07:17 AM
