turbo ignition timing and afr for mpg
Old Jan 25, 2011 | 06:50 PM
bnmm's Avatar
Default turbo ignition timing and afr for mpg
tuning friday, stock z6 turbo whats a safe afr/ignition timing for cruising under no boost maybe 1psi 3 tops
also how much timing to retard for boost, how many degree per pound?
would leaving stock timing and say like 14.7-15.7 16 afr tops be safe for cruising/ maybe no or very little boost/3,000 rpm tops. 440 injecors, idk what itll idle like im a virgin tuner lol
Old Jan 25, 2011 | 07:11 PM
bigD's Avatar
Default Re: turbo ignition timing and afr for mpg
sounds like you need to do some more reading first, for the timing I would pull 1.25 per psi. This may help get you started on the afr http://www.hondata.com/techwidebandtuning.html
Old Jan 29, 2011 | 02:52 PM
schardbody's Avatar
z6 should be fine at .75/psi but depends on how aggressive your vacuum side is.
xcountrirunr
Dec 1, 2004 08:57 AM
bmm89
Nov 21, 2004 08:17 PM
BoostedD15B7
Jan 25, 2004 08:44 AM
B_1_8_hatch
Jul 28, 2003 01:33 PM
LudeSi-93
Jun 21, 2001 07:46 PM
