obd2a body with obd2b harness? HELP
Old Jan 25, 2011 | 03:02 PM
AustinTurbo's Avatar
Default obd2a body with obd2b harness? HELP
I have done numerous searches and have come up with nothing. Here is my situation, I have a 1997 Honda Civic obd2a of course. I purchased the car as a shell and it did not come with a harness. I bought a complete engine from a 1999 Civic Sedan obd2b.
The harness I used has 2 clips for the ecu and the green one for the dash. Now I have the pigtail from the third clip for the ecu that i grabbed from the 1999 sedan but i dont know if i can wire it in?
The car runs but speedo, tach, rad fan are not working as well as the engine light is on.
Is there A way I can make this work without having to change the engine harness? I checked out the jumper harness's but they dont look like they are going to help me in this situation...
Old Jan 25, 2011 | 03:54 PM
94EG8's Avatar
Seagull Management
Default Re: obd2a body with obd2b harness? HELP
No. They have to match, there's no way around it.
Old Jan 25, 2011 | 04:32 PM
apexi_rsx's Avatar
http://cgi.ebay.com/ebaymotors/NEW-O...mZ190492823523 just use a obd2a ecu. make sure u plug the air injection holes as 99-00 civic's had air injection.check out this link. you can take the intake manifold off and plug the small holes with rivets and plug the big nipple off with a cap or cut it off and plug it with jb weld or plug it off like this guy did in this write up http://www.d-series.org/forums/diy-f...manifolds.html
Old Jan 25, 2011 | 04:56 PM
ek4_b16a's Avatar
just find an obd2a harness and swap that out
Landman93
Feb 1, 2016 01:30 PM
Civic98KH
Nov 20, 2015 04:19 PM
brandonEM1
Engine Management and Tuning
Nov 24, 2013 04:21 PM
juba_x
Sep 7, 2010 02:44 PM
Naudlee
17
Aug 14, 2006 06:25 AM
