96 accord h22 swap with h22a4 dizzy
Old Jan 24, 2011 | 01:44 PM
accordmatt's Avatar
Default 96 accord h22 swap with h22a4 dizzy
ok l have 96 accord ive done a h22 swap. i have to stay obd2 for emissions so l swapped oil pump,and using a p13-a12 ecu,h22a4 distributor. only problem l have is getting the wiring on the distributor. it has 6 wires and had 2 connectors for external coil. my stock harness had one big 5 wire plug. all colors match up cept the green on h22a4 dizzy. but it had blk/yel n blue on connector for external coil. l am using a msd blaster2 coil what wires go to what? please help
Old Jan 24, 2011 | 03:14 PM
accordmatt's Avatar
Default Re: 96 accord h22 swap with h22a4 dizzy
someone please this is all l need to be running
Old Jan 24, 2011 | 06:38 PM
nus_dogg's Avatar
Matt, I have not done an external coil before, so I'm clueless as I've been Internal all this time. We'll just have to see who's willing to chime in.
Old Jan 24, 2011 | 07:31 PM
accordmatt's Avatar
anyone???
Old Jan 24, 2011 | 07:57 PM
GhostAccord's Avatar
The green wire from the H22A4 distributor (ICM) should be hooked into the ground side of your MSD coil primary winding. That is the signal from the ICM to fire the coil. The BLK/YEL 12v wire is the feed for the coil (+). The blue wire is your tach & TCU(M) signal.
Old Jan 24, 2011 | 10:15 PM
nus_dogg's Avatar
I knew Ghost would know something about this wire.
Old Jan 25, 2011 | 05:48 AM
accordmatt's Avatar
yea actually l have tried that and no go? so if thats correct what else could it be? its turning over but not cranking
Old Jan 25, 2011 | 05:54 AM
accordmatt's Avatar
stock harness dizzy connector
yel
yel/blk
yel/grn
blue
blk
h22a4 distributor
4 plug has
yel
yel/grn
blk
grn
2 plug has
blk/yel
blue
this the wiring exactly
Old Jan 25, 2011 | 06:34 AM
nus_dogg's Avatar
Yeah, it's confusing.
Old Jan 25, 2011 | 06:58 AM
h22a4 Dist---------Accord Engine harness
yel------------------YEL (CYPP ECU C4)
yel/grn--------------YEL/GRN (Ignition input to ICM)
blk------------------BLK (CYPM ECU C14)
grn------------------MSD Coil - terminal (Primary output control)
blk/yel-------------- MSD Coil + terminal & also splices off to the BLK/YEL on the distributor (ICM - IGN Power)
blue---------------- BLU (RPM output ICM)
Make sure you don't have the YEL CYPP wire mixed up. On the F22B2 engine wire harness there is another YEL wire that went between the coil and the distributor. It went from the coil (+) terminal to the BLK/YEL (IGN) wire of the distributor.
Old Jan 25, 2011 | 07:57 AM
accordmatt's Avatar
l think l may have found problem. l am not getting power to ecu. i checked the ecu fuse under hood and inside and there good. so now what?
Old Jan 25, 2011 | 08:05 AM
accordmatt's Avatar
lm getting power to fuses inside car but no power to one under hood
Old Jan 25, 2011 | 08:08 AM
redbull-1's Avatar
Check the ECU ground on the thermostat housing.
Old Jan 25, 2011 | 08:51 AM
The ECU ground on the 96 CD5 chassis is the group of ground wires (BRN/BLK & BLK) that was bolted to the drivers side of the upper intake plenum. IIRC it is in the wire loom that went under the F22B2 intake manifold.
F22B2 CD5 G101 location
If it won't reach the thermostat housing at least make sure this is connected to the intake manifold somewhere. Also make sure that you give the area around the stud/bolt area a good cleaning with a wire brush to remove any oil, dirt, oxidation & coatings. This will ensure that you get good ground contact.
Old Jan 25, 2011 | 10:49 AM
accordmatt's Avatar
well now l have power to both fuse boxes but no power coming out of ecu connectors. i dont have a ground on intake manifold but would that cause no power to ecu plugs? l have power to all fuses and everything but not connectors to ecu
Old Jan 25, 2011 | 11:41 AM
nus_dogg's Avatar
You need to find that ground! It comes out of the engine harness and bolts up to the driverside IM. If it's not hook up, you won't get spark. That ground is for the ECU, so it needs to be hooked up.
Old Jan 25, 2011 | 12:05 PM
accordmatt's Avatar
ghost ur the shizznit l totally forgot that wire hooked up and cranked but cut off few seconds later small fuel leak and something else l gotta figure out but thank you so much
Old Jan 25, 2011 | 06:43 PM
accordmatt's Avatar
ok so now lm dumping alot of fuel. each time l pull plugs there soaked. l know could be bad fpr or vafc settings. but how do l diagnose fpr? and what other issues could cause it to crank a few times and cut off within 20-30 sec?
Old Jan 25, 2011 | 07:04 PM
What injectors are you using and how do you have them wired? What settings are you using in the VAFC. Honestly a VAFC is not the EMS I would be using for an H swap. Chipped ECU or at least a stock 96 P13. 96 no immobilizer I realize cash is tight but it would make things much easier in the long run.
Timing? how strong is your spark?
You need a fuel pressure gauge in order to test the FPR. with vacuum hose connected it should be 30-37psi and with the vacuum hose disconnected it should read 40-47psi. When you reconnect the hose if the psi doesn't change quickly, or the specs are not right when you take the readings, replace the FPR.
Old Jan 26, 2011 | 12:16 PM
accordmatt's Avatar
my ecu is for 345cc or 370cc and my stock resistor box works with those. and lm still getting plugs wet even after dif fpr
Old Jan 26, 2011 | 12:30 PM
OK so your running the 96 OBD2 peak and hold injectors. They went to 290cc high imp in the 97 H22. Brain fart....sorry!
Old Jan 26, 2011 | 01:58 PM
accordmatt's Avatar
its cool ur a huge help l appreciate all info. but u got mail of that pic
Old Jan 26, 2011 | 03:30 PM
nus_dogg's Avatar
My JDM H22A is a '96 which is still an OBD1 in Japan, and I'm doing fine.
Old Jan 26, 2011 | 05:11 PM
accordmatt's Avatar
yea but nuss ur stock obd1 also. im obd2 stock and have to stay that way to pass emissions.
Old Jan 26, 2011 | 05:21 PM
accordmatt's Avatar
yea but nuss ur stock obd1 and lm stock obd2 and l have to stay that way for emissions.
dizzy wiring is my problem now. lm not getting correct spark
