Loose shifting
Old Jan 24, 2011 | 09:18 AM
whiteteggy44's Avatar
Default Loose shifting
I just got my new exedy stage 1 clutch installed this past weekend. The clutch feels great, but now when I shift it feels loose, my stick and gearbox just feels loose in general. The gears are soggy when I shift. Any ideas?
Old Jan 24, 2011 | 09:50 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Default Re: Loose shifting
Shifter bushings
Old Jan 24, 2011 | 12:45 PM
but i dont understand because before the install it was fine my shifting wasnt loose and soggy at all. before the clutch install my shifting was tight, and now after its loose.
Old Jan 24, 2011 | 04:02 PM
94 ls-r's Avatar
cause you removed it. may have finished it off
Old Jan 24, 2011 | 05:54 PM
PatrickGSR94's Avatar
Community Builder
Active Streak: 60 Days
could be a problem with where the b!tch pin installs in the linkage. Check it out.
Old Jan 24, 2011 | 08:07 PM
hatmanafro's Avatar
The shifter bushings are just like 2 things of poly urethane right? Is it hard to install?
Old Jan 24, 2011 | 09:39 PM
tonythetuner®'s Avatar
No replacing the shift bushings are not hard it pretty simple. You can figure it out just looking at them
Old Jan 24, 2011 | 09:52 PM
ElementzofR's Avatar
they typically just pop right in with minimal effort and the right lubrication
Old Jan 25, 2011 | 07:52 AM
hatmanafro's Avatar
Good stuff. I wanna try this soon
Old Jan 25, 2011 | 08:05 AM
Community Builder
Polyurethane shifter bushings are crap. They dry rot and get super loose after only a few years. OEM rubber bushings are superior.
Old Jan 25, 2011 | 01:14 PM
igorka_91's Avatar
This is what i putt on my car last night. Took me all of 10 min.
http://www.teammfactory.com/solid-shifter-bushings
Money well spent. Feels nice and solid now.
Also do u have stock torque mounts..? I got energy suspension engine mount inserts and days and night difference between the stock ones which were ripped and the energy ones. My rear trans mount was ripped to wear the middle just came out. No more engine wooble.
Old Jan 25, 2011 | 01:59 PM
Community Builder
If you use those mount inserts, beware of extreme vibration during idle. I got the set with the torque mounts and rear mount inserts, and only installed the torque mount inserts. The vibration at idle was unbelievable. I couldn't imagine if I had the rear mount inserts installed, or even worse all mounts filled/solid polyurethane. I took the torque mount inserts out about a week later.
Anybody wanna buy some black Energy Suspension torque & rear mount inserts?
Old Jan 25, 2011 | 02:05 PM
igorka_91's Avatar
Oh yeah i forgot to putt that to. Eh i got used to it. At least i know my engine inst flopping around in the engine bay. Better then nothing untill i can get some real aftermarket mounts.
Old Jan 25, 2011 | 02:06 PM
Community Builder
yeah I ended up biting the bullet and buying brand new OEM torque mounts and rear engine mount. Not much engine movement at all yet still nice and smooth idle.
Old Jan 25, 2011 | 02:36 PM
adookie02's Avatar
where can i get the oem mounts? honda?
Old Jan 25, 2011 | 03:10 PM
Community Builder
www.acuraautomotiveparts.org
mrbuddha
Jan 28, 2011 12:30 AM
H2BSTUPID
Transmission & Drivetrain
Mar 24, 2009 11:07 AM
Pinja
May 6, 2007 09:01 AM
ProjectDarkBlack
Jan 20, 2005 10:11 AM
