Starting problem
Old Jan 25, 2011 | 01:32 PM
Alpine Mk2's Avatar
Default Starting problem
My friend has a 91 Integra Ls. He was on his way to class this morning and he lost engine power. He pulled over and tried to start it again but all it makes is a pop pop sound from the exhaust. I went to check it out thinking maybe it was a sensor or ground that came undone. Everything seems to look fine. Has anyone had a similar problem to this. I'm not a Honda guy so I don't know a bunch about them. I checked the ECU to see if it was throwing any codes. All it did was upon starting it would give a red dot then it wouldn't light up after that.
Old Jan 25, 2011 | 01:41 PM
MD426's Avatar
Default Re: Starting problem
Does it turn over at all? or is it dead and the light on the dash comes on when the key is turned for a while.
Old Jan 25, 2011 | 01:44 PM
Alpine Mk2's Avatar
It turns over freely. It just doesn't start and makes the popping noise. Could it be a clogged cat causing this?
Old Jan 25, 2011 | 01:47 PM
MD426's Avatar
Possibly. Did you check for spark? If you dont have a spark checker then pull a plug out and hold it close to the engine block and have some one turn the car over, you should see/hear a spark. Check all the cylinders and plugs to make sure it's not a problem on that end before you go cutting the cat out.
Old Jan 25, 2011 | 01:52 PM
Alpine Mk2's Avatar
Alright I'll check that when the car arrives at my house. He went ahead and just had it towed here. That kinda got me thinking it's raining pretty good right now. Maybe it's the distributor cap?
Old Jan 25, 2011 | 01:57 PM
MD426's Avatar
It could be that and a number of things. My friend had a problem like this with his civic hatch, turned out it some how jumped timing.
Old Jan 25, 2011 | 02:10 PM
Alpine Mk2's Avatar
I'm starting to think the timing jumped. When we just listened to it when the exhaust pops it sounds like the exhaust valve is open.
Old Jan 25, 2011 | 02:33 PM
MD426's Avatar
The cam gears have markings on them, when TDC there are up arrows and both of them along with white lines that line up in the middle. At the crank there is a marking on the lower cover and crank pulley that should line up as well.
Edit - To move the crank to TCD there is an access hole on the driver side inner fender. Turn counter clockwise.
Old Jan 25, 2011 | 02:40 PM
Alpine Mk2's Avatar
Thank you for all the input. I'm going to take the valve cover off tonight and see whats going on.
Old Jan 25, 2011 | 04:50 PM
N/A's Avatar
N/A
Purpose Built
It jumped timing, quit turning it over before you **** something up
Old Jan 25, 2011 | 04:58 PM
s14civic's Avatar
timing belt probably broke
EKcpe00
Nov 14, 2010 02:27 PM
dragonkx
18
Jul 16, 2010 09:31 PM
4CDFED
Aug 13, 2006 12:11 PM
steviethekidd
Jun 25, 2005 02:09 PM
daLixz25
Aug 4, 2003 09:12 PM
